02-21-2013, 11:18 PM | #1 |
C10, C20, C30 suspension question
i'm looking for front drop springs for my 69 C30. this may seem like a stupid question but i guess i'm asking if drop springs for a C10 would fit my C30 1 ton. it has a 350 5.7 in it if it makes a difference. i'm looking at the western chasis 4" drop springs for the front but i don't wanna order them if they're not gonna fit.... thanks in advance.
02-22-2013, 01:41 AM | #2 |
Re: C10, C20, C30 suspension question
They'll fit, and will work fine for driving. Just if you load it they may sag much more then a proper C30 spring.
02-22-2013, 09:55 AM | #3 |
thanks again, i wont be using the truck for towing really. would it be better to just cut the spring?
02-22-2013, 01:59 PM | #4 |
I am not sure I would cut factory springs for more then a 2" drop.
Do you have drop spindles? they give you a 3" drop, and offer a factory ride. |
02-22-2013, 02:33 PM | #5 |
No drop spindles yet, still running drums all around. So I can use c10 drop spindles as well when I convert to disk.
Posted via Mobile Device |
02-22-2013, 02:56 PM | #6 | |
67-72 parts collector,…
1) the lower a-arm 2) upper and lower ball joints 3)outer tie rods. What is your ACTUAL end goal here? I'm trying to figure out what you want to do.
02-22-2013, 02:59 PM | #7 |
I would be skeptical of a 4" drop coil for the front.
http://westernchassisinc.com/shop/fr...chevy-gmc-c10/ Never heard of one.
02-22-2013, 08:44 PM | #8 |
I think you also need to change the upper controll arm shaft to get proper alignment. The C20-30 are much thicker.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-22-2013, 10:49 PM | #9 |
i mainly just want to lower it but have it bag ready for the future, convert to disk brakes up front, and possibly run power steering. i would like to keep the 8 lug all the way around. i pulled the flat bed off last week because i'm planning on shortening and narrowing the flat bed. i just figured i would get the suspension knocked out before the bed goes back on. it's not going to be a daily driver just something to bring out every now and then. it being a 4 speed won't allow me to have it as a daily seing how i have to drive highway speeds everyday. hahahaha
02-22-2013, 10:51 PM | #10 |
thanks for the link lolife99 putting in my order tonight.
