C10 CLUB Y QUE!
slammed truck bleeding brakes
i have a 1965 GMC that im redoing the brake lines. I have the poportion valves with no reset button Mc and a brake booster.
My problem is theres pressure for the first few pumps then nothing. ive been reading for hours on brakes bleeding but i think it may have something to do with my poportion valve being lower than my calipers. Im just trying to get an idea of were to start. |
C/10 junkie
Re: slammed truck bleeding brakes
Watching
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
C10 CLUB Y QUE!
me too
67-72 parts collector,…
![]() Join Date: Nov 2002
Where did you get your prop valve?
Are you sure it's not the drum brake's "distribution block"? What M/C do you have?
C10 CLUB Y QUE!
I got the pv fom cpp over two years ago. MC, Brake booster and pv were all running on my truck fine. I just installed my PB crossmember and redid my front brake lines.
Posted via Mobile Device |
C/10 junkie
What I would do if I were you would be to remove the PB stuff and we'll swap cause then your brakes will work good
So you had disc brakes prior to installing the Dropmember?
C10 CLUB Y QUE!
Yes lolife
C10 CLUB Y QUE!
The change was PB stuff and rerouting my PV in the frame
Then I don't know what is going on.
Having the M/C lower than the calipers requires inline check valves. But the prop valve shouldn't.
Maybe the M/C just decided to go.
C10 CLUB Y QUE!
Maybe your right I guess.....
#13 |
C10 CLUB Y QUE!
I have notice that my brakes do get hard if I block my lines from mc but doesnt that mean its good mc
#14 |
![]() Join Date: Mar 2011
Did the combination valve go off center, and only let fluid go to the open side???Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#15 |
C10 CLUB Y QUE!
I checked the ground light on the pv and the light is on. How do I reset a custom pv with out the reset button
#16 |
C10 CLUB Y QUE!
Wel I just purchased a 1975 corvette Mc.. well ill find out
#17 |
C10 CLUB Y QUE!
Brakes done..... thanks guys
#18 |
So it was the master cylinder?
#19 |
C/10 junkie
Good deal Gilbert. I knew it had to be something we overlooked. You gonna keep the corvette master?
