Old 02-22-2013, 03:55 PM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Changing gears in rearend-what else
I need to change my rearend gears to 3:73 since I changed to a 700R4. What else should be done while the shop has it open?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 02-22-2013, 04:07 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Changing gears in rearend-what else
Outer wheel bearings and seals... since the axles will be out of it.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-22-2013, 05:31 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If it's a posi,there is a special additive to keep it working.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-22-2013, 09:07 PM   #4
buckskins4ever
buckskins4ever's Avatar
you already have the great setup....Its what Im running in mine......definitely change the wheel bearings and seals like said by GASoline71.......If you are doing a gear change make sure to go with a good posi......I went with a Eaton. Use the additive and Royal Purple Gear Oil.
buckskins4ever is offline   Reply With Quote
