Old 02-22-2013, 04:19 PM   #1
6twenty5
6twenty5's Avatar
230i6 to a 350v8 mount question
I have searched and found a couple of threads that touch on this but didn't find a definitive answer. I have a 64 and I have removed the 230 and have a 350 to go in. I have also purchased new motor mounts that are the same as the ones that came off of the 230. With the HEI distributor that I plan to put in, am I able to run the stock mounts in the stock locations(back two holes) without modifying the firewall?
This is how it is set up as of now:
1964 Chevrolet C-10 SWB
Fort Worth, TX
6twenty5 is offline   Reply With Quote
Old 02-22-2013, 06:15 PM   #2
64shortbed
64shortbed's Avatar
Re: 230i6 to a 350v8 mount question
Thats what i did and have plenty of room.
64shortbed is offline   Reply With Quote
Old 02-22-2013, 06:18 PM   #3
Idaho64GMC
they both measure the same on mine, I'm doing the same going from a 250 to a 350, should bolt right in
Idaho64GMC is offline   Reply With Quote
Old 02-23-2013, 12:58 AM   #4
Captainfab
60-66 Nut
I have always installed small blocks in the original location in these trucks, and have not had any problems with the HEI clearance. If you need to pull the distributor once the engine is in, you will have to remove the cap and rotor......no big deal IMO.
Old 02-27-2013, 09:17 PM   #5
toddabrown
Just did a 250 to 350 swap last weekend. Capt is correct. Just have to pull dist cap and it drops right in. Same mounts. Same holes.
toddabrown is offline   Reply With Quote
