Old 02-22-2013, 04:23 PM   #1
TexasK5
TexasK5's Avatar
Bigger tires on a 2wd
I have a 2wd blazer that I lowered when I first bought it. Now I am switching back to original (or slightly lower than original) height. I am considering running 18-20" wheels and tires in the 31-32" range, but I haven't seen many (or any) 2wd trucks set up like this. Is this just that most prefer lowered trucks where tires like this wouldn't fit very well, or am I missing something?
Lowered stance in the photo
TexasK5 is offline   Reply With Quote
Old 02-22-2013, 04:33 PM   #2
nate_g_2003
nate_g_2003's Avatar
Re: Bigger tires on a 2wd
I would think that 31 or 32 would be pushing your luck on a slightly lowered truck. I could be wrong, but I would think you would have some rubbing issues, probably while turning.
-Nathan-
1972 GMC K2500 Suburban "The Project"
2013 GMC Sierra 1500 SLT Z71 "The Daily Driver"
2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD
1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD
2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD
nate_g_2003 is offline   Reply With Quote
Old 02-22-2013, 05:24 PM   #3
fxdxharley
Just a nother gear head
fxdxharley's Avatar
you should be fine with 31's with a 2-3" drop in the front and no issue in the rear. most 20" tires range from 29-31"
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 02-22-2013, 05:50 PM   #4
TexasK5
TexasK5's Avatar
This is the current stance - I am going to be reaising the back 2-3" from where it is now. The tires in the picture are about 26.5" diameter. Based on measurements, with 31.5" on the front, I should still have about 2" to the fender
Old 02-23-2013, 10:26 AM   #5
fxdxharley
fxdxharley's Avatar
thats a good stance now. i would leave it there and just get the bigger tires. a 31 will give you about 2" of lift and will also make it look lower because they will fill up the wheel wells.
2013 HD FLHX
2000 harley fxdx
Old 02-23-2013, 08:06 PM   #6
TexasK5
TexasK5's Avatar
That's what I was thinking as well. I think the rear will need to go up a little. It may not be apparent in that picture, but right now the rear squats a little compared to the front.
By the way - nice username, I have an FXSTD
