Old 02-22-2013, 04:48 PM   #1
dirtwork
Cab Roof Marker Lamp Mounting Clips
I had to change out bulbs in two of my c30 roof marker lights. One light went fine, but the other no so well. The threaded insert clips that fit into the square punched holes in the roof came loose and were spinning. I managed to get the screws out without damaging the roof or the lense. Does anyone know a source for those clips?
dirtwork is offline   Reply With Quote
Old 02-23-2013, 10:12 AM   #2
dirtwork
Re: Cab Roof Marker Lamp Mounting Clips
Anyone else had this issue? Cant seem to find any type of j bolt that will fit right. My neighbor has to square bodies with the same lights, may have to take one off and see how gm did it then.
Old 02-23-2013, 11:48 AM   #3
buckskins4ever
buckskins4ever's Avatar
Dirtwork, I am switching out to a clear led style light on mine. If you want the original mounting clips I will mail them to you. Send me an email with your address if you want them. Otherwise I think you can purchase new through LMC truck.
buckskins4ever is offline   Reply With Quote
Old 02-24-2013, 08:23 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I have to replace one or two on my wrecker project and I'm planning on trimming down a square nut to fit the hole and either epoxy or tack weld it in.
I think they are originally tacked in.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 02-24-2013, 10:03 AM   #5
dirtwork
I did check LMC truck and buckskins4ever you are right they offer a clip which they describe as a J-nut on their site. It is the same part offered for the 73-87 trucks as well, on which those j nuts is how it was done from the factory. They are really inexpensive so I may order some and see because that would be a simple fix.
Bobs409, thats a good idea, I never thought of trying that route. I would have to epoxy mine in as the roof is not being painted right now. They are 10-24 machine screws so a square nut may be pretty close to fitting with little effort.
Old 02-24-2013, 10:33 AM   #6
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Any good hardware store should have them, I've bought them at my local Westlake Hardware before.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 02-24-2013, 10:34 AM   #7
hatzie
Moderator
hatzie's Avatar
10-24 rivet nuts might be useful.
http://www.mcmaster.com/#rivet-nuts/=lm925n
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-24-2013, 11:52 AM   #8
dirtwork
I did try the local hardware store here with no luck. I will have to try a couple others that are bigger than the one here in my travels this week. I also thought about the plastic inserts like used on license plate screws only in a smaller version.
Old 02-24-2013, 05:21 PM   #9
SS Tim
SS Tim's Avatar
Are they the same as the inner grill screw inserts on a 71-72, I just can't remember? If I can timewise I'll look up the P/N later.
SS Tim is offline   Reply With Quote
Old 02-24-2013, 06:24 PM   #10
dirtwork
The original nuts in the roof are steel, I thought about using something similar to the grill inserts to repair it.
