Old 02-23-2013, 12:42 AM   #1
72restorationvirgin
Active Member
72restorationvirgin's Avatar
Original 72 Door Panels?? Exterior Screw?
Ok so I got some original black door panels from a member and I mounted them. The PO drilled holes in the blue door panels that were originally on my truck in all four corners for stainless screws... I"m assuming the PO didn't want to get the plastic tabs.... Those panels which are also original w/ stainless trim/scrolls don't have the one exterior screw mount on the side that the black ones do.
So were the blue ones for a different year or for a different trim? Both panels are original so I don't understand. The black ones mount up perfect, tight and I don't see the need for the screw. But I'm thinking I might have to drill another hole in my door so I don't just have a blank hole in my door panel. Thoughts anyone??? I attached a pic of the black panel.
67 C20 283/4 Speed
72restorationvirgin is offline   Reply With Quote
Old 02-23-2013, 10:11 AM   #2
Lee H
Lee H's Avatar
Re: Original 72 Door Panels?? Exterior Screw?
Well, 72 door panels are one year only. I have 4 sets of panels and they all have screw holes in different places. I used new push in retainers just a few months ago and they are already starting to pull out. I think that's why people drilled holes to screw them in. One set of panels I have has no holes and one set has what looks to be factory holes at the rear edge half way between the top and the bottom. I have no idea if they came from the factory with holes or not.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-23-2013, 12:01 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Most 72 panels I have seen have one screw/ferrule that is on the rear of the panel, in the middle. I have seen a few sets where there was a screw/ferrule at the bottom, and one at the top, as opposed to one in the middle.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-23-2013, 01:10 PM   #4
72restorationvirgin
Active Member
Ok. Thanks guys. So do you think my door shells aren't 72 door shells? I have to drill a hole to mount the screw..
67 C20 283/4 Speed
Old 02-23-2013, 01:22 PM   #5
Lee H
Lee H's Avatar
If you doors have a place for a screw under the vent window as seen below then your doors are 1972. The screw was another 1972 only feature.
Old 02-23-2013, 01:27 PM   #6
72restorationvirgin
Active Member
Ok. Both doors have the vent window screw. So why wouldnt they have the screw for the door panel.... Weird
67 C20 283/4 Speed
Old 02-23-2013, 02:25 PM   #7
leddzepp
Moderator
leddzepp's Avatar
The two screws that are in the rear top and bottom corners of your panels are probably original, with the two in the front top and bottom corners being added by a PO.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
