Old 02-23-2013, 03:25 AM   #1
KrazyRay
KrazyRay's Avatar
Alcoa Wheels
Its my goal in life to one day get a 73-75 crew cab dually. I'm going to look at some aluminum dually wheels. How can I tell if they are alcoa or imitations? Any other advise would be greatly appreciated.
Thanks,
Ray
KrazyRay is offline   Reply With Quote
Old 02-23-2013, 08:59 AM   #2
rs72z
rs72z's Avatar
Re: Alcoa Wheels
alcoa's will have alcoa stamped into them on the front.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 02-23-2013, 11:20 AM   #3
80SPORT
80SPORT's Avatar
Re: Alcoa Wheels
I believe that Alcoa no longer makes the wheels for our trucks
The production date ,size and part # along with alcoa name should be stamped on the inner surface
There are still some new sets out there;I found a NOS set on Craigslist idaho last year
80SPORT is offline   Reply With Quote
Old 02-23-2013, 01:13 PM   #4
mrolds88
Re: Alcoa Wheels
Set I have has Alcoa stickers on them too.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-23-2013, 02:01 PM   #5
Desert1957
Desert1957's Avatar
Re: Alcoa Wheels
True, 16's are getting hard to find in good condition...
Desert1957 is offline   Reply With Quote
Old 02-23-2013, 02:14 PM   #6
KrazyRay
KrazyRay's Avatar
Re: Alcoa Wheels
I really like the look of the alcoas on dually trucks. Are they the most popular wheel for 73-87 duallies?
Old 02-23-2013, 08:28 PM   #7
80SPORT
80SPORT's Avatar
Re: Alcoa Wheels
The Alcoas are forged ...some of the others are cast....and Alcoa is the standard for big trucks
So most guys will refer to aluminum dually wheeels as "Alcoas"
There should be lots out there still and there are lots of shops that service the highway tractor industry that can polish and check them
Just make sure they have the correct center dia for 73-87 GM
The Ford and Dodge wheels are similar but different center
Old 02-23-2013, 11:02 PM   #8
KrazyRay
KrazyRay's Avatar
Re: Alcoa Wheels
These are from an 89 1 ton Chevy and I'm looking at them tomorrow am. I hope they work out!
Old 02-24-2013, 10:17 PM   #9
KrazyRay
KrazyRay's Avatar
Re: Alcoa Wheels
Well, How's 3 out of 6? They are alcoa wheels, but there are only 4 of them and one of the 4 is junk. The other 2 wheels are steel wheels mounted on the inside of the duallies. They came with an 89 GMC that is beat.
Old 02-24-2013, 11:56 PM   #10
wyattglock
wyattglock's Avatar
Re: Alcoa Wheels
They do make a classic set of 16" wheels for our trucks. But it is a bear to find the part number. Let me see if this link will workhttp://www.alcoa.com/alcoawheels/nor...ochure_PDF.pdf
wyattglock is offline   Reply With Quote
Old 02-25-2013, 12:02 AM   #11
KrazyRay
KrazyRay's Avatar
Re: Alcoa Wheels
A little bit of polishing and it will look like new
Old 02-25-2013, 12:05 AM   #12
80SPORT
80SPORT's Avatar
Re: Alcoa Wheels
You would normally run steel wheels on the inside duals on a 1 ton...otherwise the wheel studs would be too short
I assume the 89 is a crew cab...square body with non metric studs
If the price is reasonable I would grab them....you can always find 1 loose wheel or the wheel repair shop may be able to fix the 4th one
Old 02-25-2013, 12:07 AM   #13
80SPORT
80SPORT's Avatar
Re: Alcoa Wheels
OK...I didn't see the picture
Old 02-25-2013, 12:59 AM   #14
KrazyRay
KrazyRay's Avatar
Re: Alcoa Wheels
I went after this deal blind. 89 1 ton with aluminum wheels $400 way up in the mountains. No picture and the owner had no clue. It ended up being an extra cab 88-98 body style. It runs and drives with 454/th400, but won't pass smog, ripe CA registration, and its beat.
Old 02-25-2013, 02:05 AM   #15
mrolds88
Re: Alcoa Wheels
AAAH.. That will buff out!! That is the decal that is on my wheels.
93 K2500 xcab 6.5TD
