Old 02-23-2013, 04:18 AM   #1
wraprail
wraprail's Avatar
85 C10 4 Link 9inch Z Frame Air T56 Build
Figured was about time I started a build thread before i'm finished. It's an 85 C10 I have had for a while. Was a long bed I shortened about 6 months ago. Been collecting parts for a couple years.
I will bring this up to current state quickly with alot of pictures. I work on it every day so progress has been very fast. Been 3 weeks since tear down and work started.
Heree we go...
wraprail is offline   Reply With Quote
Old 02-23-2013, 04:25 AM   #2
wraprail
wraprail's Avatar
Re: 85 C10 4 Link 9inch Z Frame Air T56 Build
Heres where I started this time...
Old 02-23-2013, 04:35 AM   #3
wraprail
wraprail's Avatar
Fast forward to teardown complete. I don't have a frame table or jig so my garage floor will have to do. I welded stands onto my frame (at my projected ride hight) in 8 places, made the four front stands adjustable and painted around each one a mark on my garage floor so future measurments will be from same place.
Old 02-23-2013, 04:48 AM   #4
wraprail
wraprail's Avatar
I made my frame cuts for my Z at a 20 degree angle. I figured that a 2 1/2 inch Z at 20 degrees will move the front wheels (and everything else) forward just a hair less than an inch. Also I figured it would be a stronger connection. I laid out my cuts and tacked a fence for my saw so I would have a perfectly straight cut that would need no grinding. My thinking was it would be alot easier to line up the two pieces and I was right. Piece of cake.
Old 02-23-2013, 05:02 AM   #5
wraprail
wraprail's Avatar
OK here you can see why I made the front frame "legs" or stands adjustable. They are 1 1/2 tubing with 1" pipe inside. The pipe is a very tight fit but will slide. There is a set scr
ew with 2 holes. One at ride hight and one 2 1/2 inches higher.. After cutting the frame I just removed the screw, lowered the legs and reinstalled the set screw. Now the front half is right where I needed it to weld. Wprked perfectly.
Old 02-23-2013, 06:12 AM   #6
wraprail
wraprail's Avatar
Old 02-23-2013, 06:16 AM   #7
wraprail
wraprail's Avatar
Old 02-23-2013, 06:20 AM   #8
wraprail
wraprail's Avatar
I plated the inside of the frame on both sides then half ground my ugly ass welds on the outside.
Old 02-23-2013, 06:32 AM   #9
wraprail
wraprail's Avatar
On the front I did the same 20 degree angle cut only backwards this time. I could have just made a straight cut and removed the inch (or whatever I gained on the first cut) but I thought doing the same angle was best.. First reason was that I am not sure exactly how much wheelbase I added. I know it's less than an inch (I hope) but do not know exactly. Second reason I did not make a straight cut here was I wanted to keep the 2 bumper bolt holes intact. That way everything would line up and bolt back on. If I cut straaight and removed an inch the bumper bolt holes would go away. I cut just past the steering box mounting holes and the same place on other side.
Old 02-23-2013, 09:17 AM   #10
rs72z
rs72z's Avatar
Looks awsome. I'm tuning in for the rest!
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 02-23-2013, 12:36 PM   #11
luifer76
luifer76's Avatar
nice work bro Z looks good.....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 02-24-2013, 06:01 AM   #12
wraprail
wraprail's Avatar
Thanks...
So as you can see I used 2 inch X 1/4 flat bar to tie the frontr frame horns together and tied that into the factory front crossmember.
Old 02-24-2013, 09:36 AM   #13
wraprail
wraprail's Avatar
So I already had the step notch in back. Started the 4 link.
Old 02-24-2013, 09:40 AM   #14
Wrecked1982
Wrecked1982's Avatar
im not much into lowered stuff, but i really like the creativity of that frame fabrication/modification! very nice job!
Wrecked1982 is offline   Reply With Quote
Old 02-24-2013, 09:44 AM   #15
wraprail
wraprail's Avatar
Bag mounts, shock mounts
Old 02-24-2013, 09:57 AM   #16
wraprail
wraprail's Avatar
Add a little paint.
Old 02-24-2013, 10:02 AM   #17
wraprail
wraprail's Avatar
Dakota Digital SEN-201 height sensors for DHC-2000
Old 02-24-2013, 10:20 AM   #18
wraprail
wraprail's Avatar
9 inch is from a 79 Lincoln mark 5, has single piston floating brake calipers and 3.70 r&p
Moved the battery and air tank behind the axle.
Heres my water trap .......
Old 02-24-2013, 10:24 AM   #19
wraprail
wraprail's Avatar
And my Acuair valves with Dakota Digital pressure senders.
Old 02-24-2013, 10:36 AM   #20
wraprail
wraprail's Avatar
Had to cut the crossmember so I figured it was a good place for a driveshaft loop.
Old 02-24-2013, 11:13 AM   #21
luifer76
luifer76's Avatar
lots of progress man.... keep up the good work...
Old 02-24-2013, 03:08 PM   #22
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Looks great & very well documented for the rest of us to learn from!!
I'm guessing you might have done this before....
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-24-2013, 08:05 PM   #23
wraprail
wraprail's Avatar
Thanks. Never done this before but been thinking about it for a long time.
Old 02-24-2013, 08:16 PM   #24
wraprail
wraprail's Avatar
Tank drain and blow off valve
Combo
Old 02-24-2013, 08:53 PM   #25
canadian 4x4
canadian 4x4's Avatar
looks sick dude
85 swb c10 6/6 drop
83 c10 bagged and sfbd project
canadian 4x4 is offline   Reply With Quote
