Old 02-23-2013, 12:23 PM   #1
Skunksmash
Skunksmash's Avatar
Interesting idea I hadn't thought of for crusty old door panels
Down south the sun destroys our interiors as many of you know. My door panels on my 87 silverado are pretty much toast. I have looked and looked but been unable to find any that were correctly embossed for the silverado. No one makes them new, yet. And used its hit and miss. But this guy seems to have a good idea. Simply recover your old ones in Vinyl. Vinyl that has the correct texture, of course. Which it seems he did. What are your thoughts on the idea?
These days they have UV resistant vinyl that will probably hold up a lot better than that seemingly lousy factory plastic. Can you see any problems with going this route? I'd cover the whole door panel, of course. He was just experimenting it says.
http://www.ebay.com/itm/CHEVY-SILVER...5272ba&vxp=mtr
Skunksmash is offline   Reply With Quote
Old 02-25-2013, 08:22 AM   #2
Skunksmash
Skunksmash's Avatar
Re: Interesting idea I hadn't thought of for crusty old door panels
Really? No one has ever recovered door panels? I thought surely someone around here has.
Old 02-25-2013, 11:00 AM   #3
silvereagle07
silvereagle07's Avatar
Doesn't look that bad. But I would like to see the entire thing covered. The part he is showing is flat. I wonder how hard it would be to cover the bends and creases of the panels.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-25-2013, 11:42 AM   #4
Skunksmash
Skunksmash's Avatar
If the vinyl wasn't too thick for this application and you made relief cuts on the back, probably not too hard. Just gotta use contact cement to make sure it sticks. My problem is, I still need to get new door panels cause the blasted sun has warped the tops of them into oblivion. But with this idea, I can at least be able to FIND some new panels that are correctly embossed. Cause they don't have to be perfect and I can just cover them in vinyl.
Old 02-25-2013, 03:52 PM   #5
jimbonice
jimbonice's Avatar
I like the idea of just doing the the upper part of the door, in a complimentary colour. It might look alright.
jimbonice is offline   Reply With Quote
Old 02-25-2013, 04:43 PM   #6
cory d
cory d's Avatar
i used rustoleum bedliner in a can. just sanded the whole thing down then did 2 coats. it adds the texture back and its pretty dang tough
cory d is offline   Reply With Quote
Old 02-25-2013, 05:01 PM   #7
Billy81
Billy81's Avatar
I sanded mine down and sprayed them with some textured Krylon paint for plastics it came out okay but the paint makes my arm itch..lol
Billy81 is offline   Reply With Quote
Old 02-25-2013, 06:33 PM   #8
Skunksmash
Skunksmash's Avatar
Do either of yall got any pics of the end result? I'd love to see some. Gotta figure out something to do on mine.
Old 02-25-2013, 06:39 PM   #9
cory d
cory d's Avatar
it loses the shine but doesnt get chalky or anyhting. this was all sanded smooth. you can see how it adds texture back.
Old 02-25-2013, 07:33 PM   #10
68Timber
I know the pieces fit
68Timber's Avatar
The rattle can bedliner adds texture, SEM paint works well over it to give it the correct factory color. I did not do the armrest on this truck, just the door panel:
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-25-2013, 09:18 PM   #11
76stepside01
76stepside01's Avatar
I re-covered mine. Looks pretty good
76stepside01 is offline   Reply With Quote
Old 02-26-2013, 08:48 AM   #12
Skunksmash
Skunksmash's Avatar
Was it difficult to get it to stick down in all the curves and contours? That's my only concern with recovering, as one member mentioned. I'm thinking contact cement for maximum adhesion. What adhesive do you use?
Old 02-26-2013, 09:27 AM   #13
jitteryguy
GoatLube Experss
jitteryguy's Avatar
now these look good.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 02-26-2013, 06:37 PM   #14
panhead671
panhead671's Avatar
76 stepside...that is sweet...plz give us details and more pics...Ima wantin to try that!
Fris...Lover of Longbeds
85 C10 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452581
panhead671 is offline   Reply With Quote
Old 02-26-2013, 08:43 PM   #15
76stepside01
Thanks guys. I used contact cement for glue, we tried some other stuff that was made for upholstery but the cement stuck better. We had to cut around the part below the arm rest because it was to difficult to get the material to bend around all the corners, you can see this in the photo. Sorry guys I don't think I have any more pictures but ill try to find some.
Old 02-26-2013, 11:06 PM   #16
Skunksmash
Skunksmash's Avatar
Well it looks very nice, and I think you've convinced me to go that route. The SEM paint way is a good way, but I'm not confident that I can get the same results as other people have. All my paint jobs are hit and miss. More often than not, they don't turn out very well. Its only seldom that I get it perfect. And you have to use adhesion promoter, and you have to start with a very good panel that is merely faded and not half destroyed.
With your vinyl recover, they panel can be chewed up and spit out by a great white shark as long as the top isn't wavy.
Old 03-04-2013, 01:56 PM   #17
bark
Hey, I'm in Canada too, maybe I will swing by and take a look... lol
what kinda vynal did you use? I assume it must stretch alot. I think my guy can get a 6 way stretch....
Good idea, gonna have to look into it some more
bark is offline   Reply With Quote
Old 03-04-2013, 04:07 PM   #18
oldgreygoat
I have seen them done in tweed fabric before. they look pretty nice.
oldgreygoat is offline   Reply With Quote
Old 03-04-2013, 06:25 PM   #19
silvereagle07
Looks nice 76stepside01. Do you have any pics with it assembled with trim?
Jeramy
'85 Chevy 4X4 SOLD
