Old 02-23-2013, 02:25 PM   #1
belowme51
belowme51's Avatar
anyone have any expericane with 24s up front
i need to get some basic ideas for fitments on front 24s..... thinking 24x9 with 5.0-5.75 back space and a 255/30/24 or 24x8.5 with the same backspace and tire size...rears are 24x15s. porterbuilt complete front and body drop. thinking i may need mmw arms to make it work but dont want lynn at intro to cut them wrong..any help or direction is appreciated.
---mike
belowme51 is offline   Reply With Quote
Old 02-23-2013, 04:39 PM   #2
belowme51
belowme51's Avatar
Re: anyone have any expericane with 24s up front
thanks guys.
Old 02-23-2013, 08:23 PM   #3
oldspowered67C10
How is the track width on the PB front end compared to stock? I assume that your going to be trimming the front fenders quite a bit and losing the stock hood hinges?
oldspowered67C10 is offline   Reply With Quote
Old 02-23-2013, 08:32 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
8.5 wheels need at leat a 5.25" BS.
That means your 9's need at least a 5.75"BS.
They may need more.
24's are going to need a rubberband tire to air out.
Most do a 22/24 combo to help keep the tires off the hood.
Keith
Convert to disc brakes.
Old 02-23-2013, 09:31 PM   #5
buckskins4ever
buckskins4ever's Avatar
20's fill these wheel wells alot, I cant imagine 24's on one without really cutting up alot of metal....especially with 24x15's on rear.....That is a majorly wide wheel.
buckskins4ever is offline   Reply With Quote
Old 02-25-2013, 02:45 AM   #6
Chevyllac
Chevyllac's Avatar
I have a set of 24's on mine and yeah it's a lot of cutting and the stock hinges have to go but I'll tell you what, big rims look pretty good on these trucks if your into that look of course.
Chevyllac is offline   Reply With Quote
Old 03-09-2013, 05:04 PM   #7
belowme51
belowme51's Avatar
Any updated info on this, the front is pretty narrow with cpp modular spindles, wilwood brakes and narrowed MMW arms along with dropmember. ive been told from 5" to 5.5 but I need to clear a sway bar, firewall and fender too..
Old 03-11-2013, 01:05 PM   #8
Bomp
Bomp's Avatar
I plan on running 22's with average tires (not rubber band).
Builds in fabrication mode.
Bomp is offline   Reply With Quote
Old 03-17-2013, 12:01 PM   #9
belowme51
belowme51's Avatar
Ttt
Old 03-17-2013, 01:52 PM   #10
BurlyCrew
I also believe Porterbuilt drop member narrows your track width atleast an inch each side... And just run their firewall hood hinges..
BurlyCrew is offline   Reply With Quote
Old 03-18-2013, 01:15 PM   #11
belowme51
belowme51's Avatar
if my control arms are narrowed michigan metal works arms .75 each side would I be safe with a 5.5 back space.
They may need more.
Old 03-18-2013, 07:30 PM   #12
lolife99
lolife99's Avatar
You are going to have to get out a tape measure and a straight edge.
Get them TOO NARROW and it will look silly.
It's all about total tire height,... to get it to lay out.
Backspace gets it clearing the fenders.
You can mount up any bare wheel with a "known backspace" and measure off of them also.
Dropmember + CPP modular spindles + .750" narrower (per side!) a-arms equals a really narrow front end.
Bolt it all together, install a fender,... and measure.
Keith
Old 03-20-2013, 12:12 PM   #13
belowme51
belowme51's Avatar
my total tire height is 30" and 10" wide....i was im between 5.5 and 5.75 plus the body is droped .75 from the body drop.. I just dont have access to the body right now and will be a while in the body shop.
Old 03-20-2013, 12:16 PM   #14
belowme51
belowme51's Avatar
is your truck on the frame or pinch, what width,tire size and backspace do you have.
