Old 02-23-2013, 05:36 PM   #1
DjS71
Cool I've never seen one like this... (Exh Manifold)
Last post in my lackluster build thread, linked below.
I knew it had a leak, but... I was pretty amazed.
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 02-23-2013, 05:42 PM   #2
Lee H
Lee H's Avatar
Re: I've never seen one like this... (Exh Manifold)
Interesting, I've seen a few like that. Always wondered what caused it. Here's a picture from a pick a part last summer.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-23-2013, 05:43 PM   #3
Husker
Husker's Avatar
Thats wierd. Never seen anything like that.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 02-23-2013, 06:19 PM   #4
I've had one blown out like that one,but not a hole. It looked like it exploded inside,ll bulged and fractured. It happened while descending from the North Rim of the Grande Canyon. Miles and miles of decelerating and braking. When I hit the gas at the bottom it sounded like an old tractor. I got down to Flagstaff and had headers put on. I actually wanted an original manifold because I had just had the exhaust custom made before leaving on the trip. Couldn't find one,so put headers on which required a dogleg cut and welded on my fresh new exhaust. This was in '89 and the truck had about 80k on it.
The other time was about 5 years ago. One manifold cracked all the way around where it collects (just below the hole in above picture) and just dropped the exhaust down with the lower part of the manifold attached. I used tie wire to hold it back up in place till I got home,then bought headers.
Old 02-24-2013, 08:32 AM   #5
Sammy
Everyone I have seen cracked are always on the passenger side and in that area. Maybe just prone to cracking and this is the final outcome?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-24-2013, 09:34 AM   #6
It's definitely fatigue,just the end of the life of that metal being one single piece
Old 02-24-2013, 11:06 AM   #7
70CHEVYBB
70CHEVYBB's Avatar
A lean fuel mixture will dramaticly increase the exhaust tempatures. I'vwe seen the many times, but more on big blocks.
70CHEVYBB is offline   Reply With Quote
Old 02-24-2013, 01:23 PM   #8
DjS71
That's what I was thinking, given the state of the carb when I rebuilt it.
