Old 02-23-2013, 05:51 PM   #1
AirSpeed
AirSpeed's Avatar
Cargo light mounting position
I'm ordering a cargo light for my 72, do any of you have a measurement to position it? Does it require any cutting to install or just a couple screw holes and one for wires? I'm going to make it a third brake light as well. Thanks!
AirSpeed is offline   Reply With Quote
Old 02-23-2013, 05:57 PM   #2
Scott>72-GMC
Scott>72-GMC's Avatar
Re: Cargo light mounting position
Not sure about aftermarket but originals were cut in
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 02-23-2013, 06:03 PM   #3
AirSpeed
AirSpeed's Avatar
I'm kinda hoping the aftermarket light needs no cutting! I hate cutting around my newer paint! I'll probably slip and take off some paint! Anyone buy an aftermarket cargo light? Another thing, are the repops plastic or metal?
Old 02-23-2013, 06:05 PM   #4
Scott>72-GMC
If you do have to cut. Outline with painters tape. Will prevent scraping
Old 02-23-2013, 06:10 PM   #5
AirSpeed
AirSpeed's Avatar
I'll probably cut a template out of some 1/8" plywood and tape that on! I don't trust myself enough to use tape as a shield! Im good at this stuff but with my luck ill get too confident and destroy the back of my cab!
Old 02-23-2013, 07:51 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I'm sure you will have to cut and drill holes.
Here are the measurements...
LockDoc
Leon
Old 02-23-2013, 07:53 PM   #7
AirSpeed
AirSpeed's Avatar
LockDoc
Perfect! Thank you!
Old 02-23-2013, 07:55 PM   #8
LockDoc
LockDoc's Avatar
Originally Posted by AirSpeed View Post
Perfect! Thank you!
No problem. Just take your time and you will be OK...
LockDoc
Leon
Old 02-23-2013, 08:20 PM   #9
AirSpeed
AirSpeed's Avatar
LockDoc
Any idea if the ones Classic Parts, LMC and the others sell are surface mount or do they need the cab cut out in order to fit? Thanks again!
Old 02-23-2013, 08:33 PM   #10
SS Tim
SS Tim's Avatar
Assembly manual was a good call Leon. Here is a link that may be helpful to your install as well. http://67-72chevytrucks.com/vboard/s...d.php?t=528116
SS Tim is offline   Reply With Quote
Old 02-23-2013, 09:58 PM   #11
LockDoc
LockDoc's Avatar
I don't think any of them are surface mount but I have never owned an after market one.
LockDoc
Leon
Old 02-23-2013, 10:02 PM   #12
LockDoc
LockDoc's Avatar
Thanks Tim. Do you have the assembly manual on CD? The nice thing about it is you can do a search in it then just copy and paste the page.
LockDoc
Leon
Old 02-23-2013, 11:09 PM   #13
AirSpeed
AirSpeed's Avatar
LockDoc
I won't be doing any cutting until I get one, I'll just have to wait and see! I hope its not some ugly peice of plastic. Thanks again!
Old 02-24-2013, 12:50 AM   #14
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
