85 c10 Need Wheels help!
Okay so I have seen a couple of these trucks with the rims from the new Camaros on them. Do the lug patterns match up or do you need an adapter? If so what kind of adapter do I need?
Happy to be here
![]() Join Date: Mar 2000
Re: 85 c10 Need Wheels help!
The bolt pattern is not the same, so they used adapters or they were replica wheels. You can by a replica of the IROC wheel as well as some of the others in the correct pattern
do you think you could find me some adapters on the web and post a link to them?
try search....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
these trucks with 5 lugs have a 5" bolt pattern some of the newer impalas also have 5x5 pattern. Camaros and the like have 4 3/4" pattern. if you search ebay you will find some adapters. others like summit may also have them. special order is an option for new. cl/swap meets for used.
Posted via Mobile Device |
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
Not the IROCs the newer ones like on this car
http://hooniverse.com/wp-content/upl...Pace-Car-1.jpg Do they make these in the 5x5? because I have looked and I can't find proper adapters. the only adapters I can find go from 5x127 (c10) to 5x120.7 and the camaros are 5x120.
....If you need to use an adapter, then the wheels dont fit!
