Old 02-24-2013, 08:14 AM   #1
eldogg
eldogg's Avatar
I need a pic of 454 tbi
I got the motor back in my crew cab and remember for the life of me how the map sensor mounts to the intake. A pic from the right side with the air cleaner off would be a life saver.
eldogg is offline   Reply With Quote
Old 02-24-2013, 09:22 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: I need a pic of 454 tbi
Here is my 88 454 tbi
Old 02-24-2013, 01:42 PM   #3
eldogg
eldogg's Avatar
Tx firefighter you are the man! I'm going to the shop now and gonna bust this thang off!
Old 02-24-2013, 02:34 PM   #4
eldogg
eldogg's Avatar
Can I get a pic around the egr valve?
Old 02-24-2013, 04:45 PM   #5
Tx Firefighter
Here you go my brother.
Keep in mind, my heater hoses are not routed stock. Notice I have plugged the ports in the adapter under the tbi unit. Because of this, my egr valve bracket interfered with the heater hose beneath it so I modified the bracket to cant it up and give the needed clearance.
Old 02-24-2013, 04:47 PM   #6
Tx Firefighter
The hard plastic line on the top bib of the egr solenoid comes from the throttle body. The lower bib on the solenoid has a rubber hose running from it to the egr valve itself. It was originally a plastic hose but was too badly damaged so I just substituted rubber in its place.
Old 02-24-2013, 07:15 PM   #7
eldogg
eldogg's Avatar
Thanks a ton. Guys like you and others on the forum are what makes this forum the BEST. PM me your address and I will send you some QCS swag. Mine's not stock either. It has an Edelbrock tbi intake and I figured I live in GA not Alaska so my heater hoses are routed just like yours. It getting close to camping & race season so the dually has to be back together.
