Old 02-24-2013, 06:41 PM   #1
Jayschevy
Vacuum question
I purchased a 71 C10 last summer. The truck runs great. The PO rebuilt the engine adding a HEI and a bigger carb. I love the truck but did'nt like the manual brakes so I just added power brakes. However, the brakes still feel like manual brakes. After checking my vacuum, my question is what should my vacuum range be for my booster to work properly? I'm getting between 13 to 15 vacuum readings (mostly 13 - 14). Is this enough vacuum for the booster?
I've check and don't see any area's where I may be loosing vacuum. I read somewhere that some modified engines do not put out as much vacuum.
What are my options? Is 13-15 vacuum readings good and or should I just add a hydroboost brake system?
Jayschevy is offline   Reply With Quote
Old 02-24-2013, 07:14 PM   #2
Lee H
Lee H's Avatar
Re: Vacuum question
Tell us a little more about your swap, new parts, used parts? What type of booster/master? Most say 18 inches of vacuum are needed for power brakes, I've got 13-14 at 750 RPM and my power brakes work just fine.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-24-2013, 07:17 PM   #3
yuccales
yuccales's Avatar
Re: Vacuum question
I've got a very steady 17in. and my power brakes work great. Have you checked your vac. with the booster line off and plugged?
yuccales is offline   Reply With Quote
Old 02-24-2013, 07:28 PM   #4
Jayschevy
Re: Vacuum question
I'm using a new MC and booster power brake conversion kit. And I plugged all the lines and took readings directly from the manifold port.
Old 02-24-2013, 07:48 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Vacuum question
Is that from the port at the rear of the manifold? And is your vacuum line big enough?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-24-2013, 08:33 PM   #6
geezer#99
geezer#99's Avatar
Re: Vacuum question
Bump your timing up and your vacuum will increase too.
What's your timing at now?
Old 02-24-2013, 08:43 PM   #7
buckskins4ever
buckskins4ever's Avatar
Re: Vacuum question
You didnt say if you were pulling your booster vac off of the manifold or carb? I came into an issue of vac pressure when using the manifold. Better off using back port of carb....direct pull of vacuum. also make sure all ports are plugged one way or another on the large carb and small leaks will drop your pull.
buckskins4ever is offline   Reply With Quote
Old 02-25-2013, 03:30 PM   #8
msgdsrf
Re: Vacuum question
I would bleed brakes again. You have enough vacum for booster.
I would continue to use manifold vac outlet for booster and not the carb because that should be your pcv, otherwise you'll either be running crankcase crap into only one cylinder with pcv into the manifold vac (way too lean) or if you T for carb then chance of muck in booster.
msgdsrf is offline   Reply With Quote
