Gauge Bezel bulb receptacles?
I have replaced all the gauges in my bezel with aftermarket guages except the speedo and fuel gauge. Since I can wire the fuel gauge independant and the speedo just uses a cable figured if I could find some replacement receptacles that use wires instead of the green circuit board, would make life alot easier.
Does anyone know if receptacles like this exist? |
Re: Gauge Bezel bulb receptacles?
Check classic parts or classic industries.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
Measured the hole, it is 5/8" Can't find anything that takes a 194 or 168 bulb that isnt the printed circuit connector
#4 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
.......http://67-72chevytrucks.com/vboard/s...d.php?t=110613
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Yeah I had found that thread before and in post 2 it states:
"Notice that an Autometer gauge light goes where the factory twist ones went. ( another nice Surprise!)" So I did try and use the autometer lights in the factory holes. The Autometer lights I have would fit a 1/2" hole not the 5/8" holes. Those posts were made in 2004 and 2005 so wonder if Autometer had made a change to their light sockets then or maybe the 5/8 " were for the 3 3/8 guages which they dont carry any more. |
More Cowbell....
In case you were not aware, AutoMeter has at least two types of bulb holders in their gauges. One is a twist in type (similar to our factory ones) and the other one is a snap-in kind. You just push straight in..no twisting required.
You might also try a common 'tag-light' replacement socket (think mid-80's C-10 rear bumper) from the local parts house. Most are closer to a rubber-material than hard plastic. They push/twist.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
I did look on there site...
Autometer lights and bulbs I found a couple that thought "could" fit.. They have this one: 3220 and this one.. 3211 Thet dont give a hole diameter though, only say what guages they will fit. Summit carries them was waiting for them to open and ask them about the 3211... |
Summit has not other info on them either. About to call them and have them pull one
I bet you could solder a pig tail onto the ears and make yours hard wired.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant |
#10 | |
I had thought about that too however they would ground out on the metal housing... unless of course I put a rubber washer there or something. Thought it would be easier and quicker to just by sockets that would fit. Im going to head to NAPA at lunch and see what they have. Waiting for a call back from Summit. |
Found a solution....
Went to Advance to see what they had for light receptacle. Found Dorman number 85814, Says Primary application is GM and Ford sidemarkers 1995 through 72. It has 4 tabs on it so with a razor and removed 2 and trimmed the remaining 2 to fit the slots. Works like a charm. Thanks to those who tried to help ![]() |
