Old 02-24-2013, 08:47 PM   #1
Horsman
Horsman's Avatar
402 with Edelbrock Performer intake
Recently started over with a rebuild on my 402. Thinking of changing the cast iron intake because of coolant seepage thru the casting in one small area. Looking for opinions on the Edelbrock Performer on a stock rebuild.
Any issues with the way the heater hoses, vacuum lines, and throttle cable attaches? Going to stick with my Quadrajet.
Any opinions and/or advise appreciated. Anyone with pics of the same set up, please share.
Thanks in advance!
Jeff Horsman
1972 C20 Highlander "C"
1966 Olds 442 L69 four speed
1971 Skylark (GS clone racecar) 494 stroker
1986 Buick T-Type
Horsman is offline   Reply With Quote
Old 02-24-2013, 09:00 PM   #2
Frostflowz
Re: 402 with Edelbrock Performer intake
They're good for bottom end, worth a few ponies over stock anyway. They do look better then a cast manifold as well. If you're running stock heads with a stock cam a performer manifold will do just fine.
Frostflowz is offline   Reply With Quote
Old 02-24-2013, 09:53 PM   #3
trac209
Depending on what your doing in the rebuild. I would go with a matching cam to really improve the torque of that 402. I had a Monte Carlo with a 402 bb I ran a performer camshaft iirc it was around 512 lift. It pulled hard.
trac209 is offline   Reply With Quote
Old 02-25-2013, 08:23 PM   #4
cpetersen
cpetersen's Avatar
FYI. If you get a air gap make sure you the ARP 502 bolt set. They are a bit longer. You will need it. The air gap is a great intake too check it out.
cpetersen is offline   Reply With Quote
