Old 02-24-2013, 10:28 PM   #1
MacsGTO
Carb issues?
My first time really posting so thanks up front for any guidance. I have a '65 with the factory 230. Only mods that have been done is that I have removed the oil bath and added power steering, power brakes and an HEI dizzy. She runs and idles smooth but when it warms up after I've been driving for a little she starts to sputter during acceleration from stops. After you level out at speed she runs fine. I'm 98.7% positive it's a carb issue but I don't have a lot of experience with these single barrels. Also, it did this before the HEI swap which helped lead to the swap. What and where are the adjustments? I think I'm running rich because I've had to play around with some choke issues as well. Any thoughts?
Very respectfully,
George
MacsGTO is offline   Reply With Quote
Old 02-25-2013, 12:51 AM   #2
dracko
dracko's Avatar
Re: Carb issues?
Sounds like it could be the accelerator pump or nozzle/bore. Maybe the cup is warped and leaking or the bore needs a good cleaning. If you replace the pump try to get one that is ethanol resistant. Also couldn't hurt to blow compressed air through the idle jet.
Here is a Rochester B service manual that might be helpful:
http://chevy.oldcarmanualproject.com.../5020mts00.htm
dracko is offline   Reply With Quote
Old 02-25-2013, 07:31 AM   #3
MacsGTO
Re: Carb issues?
Huge help, I can't thank you enough.
Old 03-01-2013, 11:57 AM   #4
dracko
dracko's Avatar
Re: Carb issues?
Ya no problem hope you get it sorted.
