Old 02-24-2013, 10:58 PM   #1
BMERDOC
BMERDOC's Avatar
6 cyl Alternator Swap Questions
So I researched until my eyes bled using the forum search function. I know I probably could research Google but frankly I'm tired so I'll just ask.
I found that my 250 alternator has 12 and 6 o'clock mounting points and the connector is at 3 o'clock. I also need a V belt pulley. I am going to be upgrading the truck with modern amenities like headlight relays, power windows, stereo...so on. I figure 100amps is mininmum for what I need. I found an alternator on Summit Racing..
http://www.summitracing.com/parts/tff-7127-100
The price seems right but I think I might be buying a Chinese product again. Anyone have experience with Tuff Stuff? Anyone have a better option within my parameters?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 02-24-2013, 11:20 PM   #2
buckskins4ever
buckskins4ever's Avatar
Re: 6 cyl Alternator Swap Questions
The best question is how much stereo are you going to do.....AMPS subs, high powered deck??? I would really suggest a 140amp and summit has the PowerMaster 47294 which is for your truck. Its a bit higher price, but with all the added amp draw you are adding I would want to be safe.
buckskins4ever is offline   Reply With Quote
Old 02-24-2013, 11:41 PM   #3
BMERDOC
BMERDOC's Avatar
The stereo will be humble because it will all be hidden (more on that later ) It may have two mild amps or an amp and a powered sub. Knowing what I know about charging systems I shouldn't need more than 100amps. The truck is a fair weather, non-A/C truck. 120amps would be overkill for my system. Not to mention a High Zoot alternator has no place in this truck in its current condition. I would prefer a stock looking case.
Budget matters too. I am moving the battery behind the LR tire and unwrapping and modifying the front harness to delete the external regulator and include a new headlight harness. Everyone of my projects starts to snowball after a while. I need to pump the brakes and show some restraint. If I can upgrade the charging system now I can upgrade to a larger alternator later if need be.
Nick Carter
Old 02-25-2013, 12:15 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
check out this thread.
..........http://67-72chevytrucks.com/vboard/s....php?p=5900769
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-25-2013, 10:11 AM   #5
BMERDOC
BMERDOC's Avatar
Ha! Thanks Vet! All that research using the search function and that one never came up! :/ And so current too!
Nick Carter
