Rear sway bars
anyone running rear sway bars on there 2wd? any pics? does it work well with a drop? thanks
Re: Rear sway bars
My crew cab dually has a rear bar stock. I bet you could swap one on a half ton.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
Re: Rear sway bars
That's a big bar. I thought about it but then figure, that's to much weight... Just kidding. Someone said you don't want one to thick in the rear. Will affect the handling on turns and such
2004 Silverado Crewcab (Dark Spiral Gray) |
Re: Rear sway bars
yup my one ton has one on it too
Parts and more parts
Re: Rear sway bars
I put a sway bar on my lowered 84 GMC quite a few years ago. I purchased a Helwig unit that was built for a lowered mid eighties truck. It works very well on the truck. I don't have pictures of it, but it is all bolt on assembly. The only thing that I did different, was to mount the front end bar links to the frame vice using the Helwig brackets, and it looks better than if I had drilled for the brackets and used them.
http://www.sdtrucksprings.com/sway-b...FQGEnQodm2QAQg
Frank |
Re: Rear sway bars
I have a belltech 1 1/8 bar on my truck. It was pretty easy to install and definetely tightens up the truck in the corners. It's a good investment.
![]() Join Date: Oct 2009
Re: Rear sway bars
Isnt that the purpose, to affect the handling? In a good way. Thicker bars are better than thin bars. Thats why the aftermarket makes them thick.
Re: Rear sway bars
Was factory on some of the 1 ton dually's. My 79 1 ton single rear wheel didn't, however I added a factory rear bar from a 1 ton and immediately noticed a difference, in a good way.
So I bought another factory 1 ton rear bar setup to add to my 4x4 blazer. No complaints here. I say if you can find one, go for it. They really aren't all that big in diameter as far as sway bars go. |
Happy to be here
![]() Join Date: Mar 2000
Re: Rear sway bars
Here are some pics of the install diagram, and what the factoru components look like.
Re: Rear sway bars
Yup
![]() Easy to install, and best of all, looks OEM because it is. None of that cheesy aftermarket u-bolt clamp stuff on the housings. Sweet part is the oblong holes in the cast iron brackets so it can be adapted to a variety of difference sized axle tubes (since the u-bolts vary in width). |
Re: Rear sway bars
And here's a pic of what that bar looks like installed...
Re: Rear sway bars
I would just like to point out that bar diameter isn't always indicative of how much it resists torsion. A lot of the larger bars are hollow with a significant wall thickness.
Also, for the most part I have observed that the 30/35/3500s are mounter axle to spring with ubolts opening down; whereas 10/15/1500 & 20/25/2500 are the opposite, they open up. Something to consider when looking for the factory bar.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
#13 |
Re: Rear sway bars
Yes, and for the 3/4 ton axles (since the U-bolts face the other direction) GM used a different sway bar that had cast iron plates that attached to the axle tubes instead of the spring pack, and then the bar attached to that.
Good luck finding one of those, they are more scarce then the 1 ton bars. I had the 3/4 ton setup at one time I was going to use. However that isn't always the case. My 72 blazer 4x4 which is basically 1/2 ton suspension, works just fine with the 1 ton rear bar setup. |
#14 |
Home Built '87
Re: Rear sway bars
x2
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
#15 | |
Re: Rear sway bars
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#16 |
Re: Rear sway bars
I would much rather have oversteer than understeer. Nothing worse than the feeling of a vehicle that won't turn the direction you want to go, but that's just me.
I'd think that aside from having perfect balance, a performance car driver would probably prefer the same. I'm guessing most of us here aren't driving pickup trucks in performance road course situtations, I know I don't, I have other cars for that. I simply added the bar for more stability while towing. The OEM bar is cheap and affective, and it fits. It suits the purpose perfectly. |
#17 |
Re: Rear sway bars
firebird,
are the holes on the frame already there or do you have to drill them. Im planning on doing this, soon as I find one a the PAP. thanks |
#18 |
Re: Rear sway bars
I had to drill mine.
#19 |
Re: Rear sway bars
With my set up:
1 ton bar up front and the 1 1/8 bar out back its a good balance. I dont have crazy oversteer issues aka "drift truck syndrom". I have taken corners at 70+ and gone through the canyon roads on mulhulland with this setup too.. It has a great balance. I think for someone looking to make a difference in handling and for someone that pushes their truck either bar will do the job. |
#20 |
![]() Join Date: Jun 2009
Re: Rear sway bars
It looks really great Larry!
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
#21 |
Re: Rear sway bars
Thanks to you
#22 | |
Re: Rear sway bars
Some of the torsional stiffness of that 1" bar is diminished by the length of the arms. They are considerably longer than the typical car bars. The extra length increases the leverage, so it takes more diameter to have the same effect.
In general, the factory designs in a bit of understeer. "Pushing" or "plowing" is a safer condition for the average driver. Simply letting off of the throttle brings the vehicle back in control.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#23 |
![]() Join Date: May 2009
Re: Rear sway bars
