02-25-2013, 02:00 AM | #1 |
C notch info
Converting 72 K5 4X4 to 2 wd. Looking for c-notch for K5 4x4 frame, any help would be greatly appreciated.
Posted via Mobile Device |
02-25-2013, 03:10 AM | #2 |
Re: C notch info
should be the same notch as a 2wd,,or just make one
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
02-25-2013, 07:16 AM | #3 |
Re: C notch info
Looking for the same thing. I have a 4wd frame so it is pretty straight in the rear. Looks like all the c-notches are for the 2wd frames that get wider in the rear. I thought of flipping over the 4wd rear bump stop mounts and using them for a notch.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
02-26-2013, 12:12 AM | #4 |
Re: C notch info
the frames get wider,,i never knew that,,,,sounds funny to me
02-26-2013, 04:47 AM | #5 |
Re: C notch info
Yeah. They get wider so the trailing arms can use the coil springs so trailer hitches are different widths etc. I just kept the leaf springs from the 4wd. So all the notches I've seen follow that curve where the frame widens. Check out the thread-"Family Truckster". Not sure how to post the link. I really like his notch and it started as a 4wd. Man got some skills!http://67-72chevytrucks.com/vboard/s...4&goto=newpostthere you go.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 02-26-2013 at 04:54 AM. |
02-26-2013, 06:17 AM | #6 |
67-72 parts collector,…
Re: C notch info
The 4x4 frame rails are straight.
I would look at using a 73-87 c-notch. I've never done it myself. Posted via Mobile Device
02-26-2013, 11:44 AM | #7 |
Just a nother gear head
Re: C notch info
use a 73 up notch or make your own from 3/16 or 1/4 plate. that what i did on the 84 i had before notches were available.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
02-26-2013, 01:08 PM | #8 |
Boosted Member
Re: C notch info
I used 6" diameter 1/4" wall pipe to make mine for my 4x4 to 2wd conversion.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
02-26-2013, 01:33 PM | #9 |
Re: C notch info
that whats in my 69 4x4 frame converted to 2wd. before i got it.
