Old 02-25-2013, 09:12 AM   #1
superwade57
what year wheels will fit
I have a 71 2wd 3/4 ton what year steel wheels will interchange?
superwade57 is offline   Reply With Quote
Old 02-25-2013, 11:06 AM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: what year wheels will fit
Any year with the right bolt pattern.
Year doesn't really matter much, some years these trucks were offered with 5, 6, and 8 lug wheels depending on equipment.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-25-2013, 11:40 AM   #3
Longhorn 70
Longhorn 70's Avatar
F**d, D**ge and GM used 8 lug on 6.5" patterns. They will all fit IF the center hole is big enough and clear your front brakes. I found some of a 74 for my old beater. I even have some from a 91 Chevy 3/4 ton on mine as spares right now.
Look for years with front disc brakes and you should be good.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 02-25-2013, 12:25 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Ford changed their 8-lug bolt pattern to 170mm in 1999. As stated above, all others will be 8x6.5" and should work as long as they fit over the axle stub (shouldn't be an issue as our axles are generally smaller than or equal to most others) and if they clear the front calipers.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
