Old 06-15-2003, 06:07 PM   #1
superchevy
Got big-block?
superchevy's Avatar
FS in Dallas: 5 lug disc swap kit.....
SOLD!!!
I removed all these parts from my '72 shortbed today. Everything is in very good shape - you could bolt on and go - or do I like I did and repaint/refinish/restore one set while you drive, then switch over when you're ready.
You get everything pictured for a complete swap:
Upper and Lower control arms with bushings and balljoints
Spindles with turnable 5-lug rotors and good calipers/pads
Center link with good attached inner and outer tie rods
Idler arm and pitman arm
This is everything you need (less the brake booster/master cylinder) to convert your 67-70 1/2 ton to a 5 lug disc brake front end. You could literally unbolt your front end and bolt this one on if you wanted to.
This stuff is heavy. You might want to pick it up.
If you need it shipped, we could probably do it fairly cheaply ($50-$60??) through Greyhound bus lines to a terminal near you.
$125 plus shipping if needed.
You can email me directly at carpediem_00@yahoo.com
superchevy is offline   Reply With Quote
Old 06-16-2003, 08:12 AM   #2
superchevy
Got big-block?
superchevy's Avatar
ttt
Old 06-16-2003, 08:58 AM   #3
BigRed
You selling that bed?
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 06-16-2003, 10:31 AM   #4
superchevy
Got big-block?
superchevy's Avatar
No, the bed's not for sale.
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
Old 06-17-2003, 06:31 PM   #5
superchevy
Got big-block?
superchevy's Avatar
SOLD!!!
Thanks, SC.
