02-25-2013, 03:08 PM | #1 |
Big block with drop spindles?
I have a '71 with a 402. I added drop springs a few years ago, but want to go a little lower. Are there any issues with drop springs AND spindles with a big block? It has disks and a 5 lugs, a factory 1/2 ton.
Thanks gurus Chris Last edited by Chris Binnett; 02-25-2013 at 03:09 PM. Reason: wrong tense... |
02-25-2013, 03:14 PM | #2 |
67-72 parts collector,…
Re: Big block with drop spindles?
No issues.
Welcome to the board!
02-25-2013, 04:19 PM | #3 |
Thanks, I've been lurking for 5 years...but I just now decided to tap into this VAST pool of knowledge!
Chris |
02-25-2013, 04:20 PM | #4 |
Moderator
My 72 BB has both. Welcome to the board!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-25-2013, 04:55 PM | #5 |
Florida Edition
Also welcome from the shadows. My 70 Big Block rides on 2-1/2 drop spindles and 1/2 a coil cut off of a new stock BB spring (the same as a 3/4 ton spring). Any lower and the floor jack won't go under my crossmember.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
02-25-2013, 05:09 PM | #6 |
Is there a lot of difference between big block springs and regular springs?
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
02-25-2013, 09:04 PM | #7 |
Hey RenoKeene,
What did you do to the rear end...your ride has a nice stance. I don't want to do anything stupid, so I'd like to follow in someone's footsteps. I don't want to notch the rear... C |
02-26-2013, 12:09 PM | #8 |
Florida Edition
5" drop springs, shock relocator kit with new stock shocks and a adjustable track bar, thats it....no problems with rearend to frame contact (no notch).
02-26-2013, 12:30 PM | #9 |
Man of Mini-Talents
Yes there is, in terms of spring rate. If you use a regular spring, it'll ride about an inch lower and you've used up some of your travel.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
02-26-2013, 12:33 PM | #10 |
Is there a proper way to cut a spring for lowering ???
