Old 02-25-2013, 03:39 PM   #1
71K20chevy
71K20chevy's Avatar
Need help identifying tilt column spring
I got the CPP repro tilt column, and with the shift lever it came with this spring. However I can't figure out where it goes!
Could anyone please enlighten me on how and where to put this spring in at?
Thanks!
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 02-25-2013, 03:50 PM   #2
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Re: Need help identifying tilt column spring
hard to tell because I dont have anything as a size referance. but assuming because it came with a shift lever I would say it is the spring that puts tension on the shift lever. if you are sitting in the truck and have the shift lever removed (along with the pin odviously) the spring would sit inside that opening a little more toward the cluster. One end rests in a pocket inside of the shift housing and the other end presses on the shifter. I just dissambled my column and could not easily remove my spring but I have had others that have fallen out once everything is removed. All of this is for an auto, I do not have any 3 on the tree shifter experience.
Thanks, John
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 02-25-2013, 03:57 PM   #3
Xeen
Xeen's Avatar
Thanks!
That is the spring that snaps the shift lever back after you pull it, the spring is inside the tilt housing and it pushes against the base of the shift lever, if you look inside the opening for the shift lever you will see a spring and if you dont then you need to instal that one.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 02-25-2013, 04:11 PM   #4
71K20chevy
71K20chevy's Avatar
Well that answers my first question, but not I can't figure out how to keep the dang ting in place while I put the lever in! Any ideas?
Thanks for the help so far!
EDIT-Nevermind, got it. I didn't have the spring in the pocket far enough. Thanks for helping me guys!
71 K20
64 GMC mud truck
Old 02-28-2013, 12:22 PM   #5
ChevyCruizer
17's too small
I set the spring into its location inside the column with a thick glob of grease to hold it there. then work the tip of the shifter into place while putting some pressure on the spring. Finally keep applying pressure to the spring and align the shifter with its locating pin and drive the pin into place. You might need a buddy to use a hammer and drive the pin down, but I have been able to do it alone before.
Thanks, John
