Old 02-25-2013, 04:20 PM   #1
Mustard72
Mustard72's Avatar
A-arm shaft wear
I've searched a bit on this forum, but didn't see the answer I'm looking for. I've got some play in the upper a-arm between the arm and the shaft on my '72 C20. If I replace the shaft bushings, will that eliminate the play? Or will the arm be worn, too? Seems like the arm is a wear part in this scenario, too. I suppose this might be a situation where it depends on the amount of wear, right?
Thanks in advance.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 02-25-2013, 05:31 PM   #2
LEEVON
Moderator
LEEVON's Avatar
Re: A-arm shaft wear
Bushings should take care of it. I suppose if your bushings were absolutely toasted and there was metal-to-metal contact then you could wear the cross shaft, but I would still think a new bushing would cover some wear. You can buy complete cross shaft assemblies if you need the peace of mind. If it were me, I'd take it all apart and go from there, unless you just want to shell out the dough for new shafts now or take a chance.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
