02-25-2013, 04:21 PM | #1 |
5 inches of drop in the front with 15x8 and inner fender wells?
I have 3 inch drop spindles up front and am gonig to chop a coil up front for another 2 inches hopefully. I am running 15x8s. With 5 inches of drop up front is it usually necessary to remove the inner fenders or anything?
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD 1998 Trans am, mostly stock with magnaflow catback My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329 |
02-25-2013, 04:45 PM | #2 |
Re: 5 inches of drop in the front with 15x8 and inner fender wells?
tire size?
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
02-25-2013, 04:51 PM | #3 |
P255 70r15
02-25-2013, 06:01 PM | #4 |
Cruzzzn' Vet
Go with a 245/60
02-25-2013, 06:21 PM | #5 |
02-25-2013, 06:23 PM | #6 |
same size i have and i rub. new tires so im just going to bring the front up a little
02-25-2013, 07:22 PM | #7 |
prob rub on the inners...rip 'em out!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
02-25-2013, 07:42 PM | #8 |
I figured it would, thanks guys. Going to either pull the inner fenders out or just raise the back up and not lower the front anymore.
02-25-2013, 10:59 PM | #9 |
I did the same amount of drop and did not have to remove the inner fender.
02-25-2013, 11:02 PM | #10 |
Watch out for your cornhole !
02-25-2013, 11:09 PM | #11 |
02-25-2013, 11:18 PM | #12 |
That explains it then. Your tires are two inches shorter than his are (27.05 vs 29.05)
Sounds like the op will be in the market for lower profile tires pretty soon. Posted via Mobile Device |
02-25-2013, 11:22 PM | #13 |
Yep, looks like paint may have to wait a bit
02-26-2013, 02:02 PM | #14 |
I have 30" tires with 3" spindles and 1.5" coils..and I'm not even close to the wheel wells...I guess you probably get more drop cutting older coils..
02-26-2013, 04:48 PM | #15 |
Gonna cut a coil on the front and see if I need shorter tires... If I do I'll get some. Mine need to be replaced soon anyways. What tire do you all recommend? And how wide of tire can I put on the back for a 15x8 wheel? I have read 275 is the widest for a 8 inch wheel... Is this true, or is that still too wide?
02-26-2013, 05:34 PM | #16 | |
02-26-2013, 05:55 PM | #17 |
255/60/15 front (27") 275/60/15 rear (28")
02-26-2013, 06:25 PM | #18 |
been here longer than Liz
What they said. I ran 255/60s on stock ralleys back when my pickup was that high.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
02-26-2013, 06:37 PM | #19 |
The 295/50/15 on an 8" wheel doesn't look good to me. I run 275/50/15's on my truck all around with factory 8's. But they are old now and dry.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
02-26-2013, 08:41 PM | #20 |
Ever considered cutting half a coil and seeing just how close you are to rubbing? Just an idea to get you by until you get shorter tires.
02-27-2013, 03:42 PM | #21 |
Cut a coil in the front and tires rubbed... Got some new ones coming.. should be here tomorrow. Got BFG radial TA 245/60 r15 in the front and 275/60 r15 in the rear.
02-27-2013, 03:43 PM | #22 |
Truck also sits a lot more level and looks much better now!
