![]() Join Date: Sep 2012
Cowl hoods
I was wondering if there was any good or bad opinions on the steel cowl hoods that are out there as far as fit wise. Is the fit on them good or bad and is there only one size cowl hood out there, only one i see is a 2 inch i believe. I am thinking of putting one on my 69 fleetside prostreet I am building.Thanks in advance for any feedback.
![]() Join Date: Mar 2011
Re: Cowl hoods
Very seldom is the fit perfect! But, with some time and effort in making adjustments you can get them pretty close.
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
Re: Cowl hoods
I bought mine from LMC and it fit fairly good. The gaps arn't perfect but are close. I didn't care for the foam they use in place of the stock felt.
69 Chevy 4x4 383 Power ![]() |
Re: Cowl hoods
here's mine , gaps good but was a pain in the a$$ to get there
Re: Cowl hoods
Thanks for all the help guys, one other question if I may, what kinda work is involved with it, is it cutting and welding type work or metal bending and working type stuff. once again thanks for everything!!
Re: Cowl hoods
Most of the work involved will be working with everything in the front clip. Loosening, moving, adjusting, tightening, inspection-----then start over.
There are different mfger's some of them ae better than others. If its real bad, you may not get it really close. Mine was close and I think I could have gotten it closer (?) but I decided to go old school and back to stock.
Re: Cowl hoods
Ok thanks a ton, I was debating whether or not to do itbut not sure if I will or not, maybe when I get ready to paint and all the stuff comes off .
Re: Cowl hoods
Be sure to fit it before you paint , it might take some time and several tries to wiggle, adjust----maybe even "massage" the fit.
Re: Cowl hoods
Not to hijack the thread, but I think it relates!
How much "massaging" do the LMC truck doors need? Are they even worth buying? Posted via Mobile Device
-Bruton 1968 GMC long bed 5.7/700R4 --I'd rather push a Chevy, than drive a Ford.-- |
Junior Member
Re: Cowl hoods
I got the 2 inch cowl hood for my '67 from LMC. If I had it to do over I think I would call some vendors and see how their cowl hoods fit and the quality.
We did manage to get the cowl hood to fit ok, but not perfect, but had to do some shimming on the fenders and grill to get it to be ok. I have seen two cowl hood heights, a 2 inch and a 4 inch.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Re: Cowl hoods
Im beginning to think I should stay with the stock hood lol!!
Re: Cowl hoods
I have a goodmark 2 inch cowl on my 88 1ton and it fits the best i have seen but looking closely it still is not perfect. For some reason the aftermarket just never seems to fit as good as original from hoods to doors to even weld in parts like rockers and cab corners. My 71 is in the middle of getting rocker, floor pans, cab corners and all the typical things that usually rust out on these pickups and none of them have been a perfect fit.
1988 Chevy 1-ton 502/gear vendor overdrive 1971 shortwide 350/350 1991 Jeep wrangler 350/400 atlas II 1-tons |
#13 |
![]() Join Date: Dec 2004
Re: Cowl hoods
i made my own cowl hood with 2 stock hoods,,nothing fits better then stock
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
#14 |
![]() Join Date: Dec 1999
Re: Cowl hoods
Actually when these trucks were new they was not a good line on them! JS!
#15 |
Thats pretty darn nice for a home made cowl hood. Looks sharp!!
