Radiator Mount Assembly
When putting the new radiator mounts in, are the square washers supposed to go on top (or inside) of the rad support or on the bottom of the rad support? They were on top before but this truck has been apart in the past by the PO.
Thanks!
Gary Slowly looking for my next 67-72 truck |
Re: Radiator Mount Assembly
anyone been through this?
72 GMC super custom. ![]() |
I saw that picture in LMC also, still left me scratching my head a bit...
The way I'm seeing it is everything above that spacer / sleeve is on top everything else below.
I believe the square should go on top since there is no hex head on top of the bolt it should prevent the bolt from spinning when tightening
I think that is correct, since the hole in the core support came round from the factory from what I have seen.
![]() Join Date: May 2010
On top of core support.
Check out Bruce88's build thread, post #446 - excellent reference for the body mounts
It’s Just A Pickup, post #446
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#10 | |
![]() Join Date: Oct 2012
Just did this myself, square washers sit on the top side of the core support (visible when looking down) with the carriage bolts through them.
