02-25-2013, 09:49 PM | #1 |
1972 402 Restored quadrajet 7042206
This is a 1972 402 Chevy and GMC.
I had a few carbs done by a guy who has over 40 years experience rebuilding carburetors and has done thousands. This carb has just been restored and is ready to install. The rebuilding extras include NEW bronze bushings installed in base. ALL rebuilt quadrajets should have this done. The bases are aluminum and the shaft bores wear and cause poor idle and vacuum leaks. All NEW primary throttle plates are installed. They are also aluminum and wear out. The secondary air valve cams are plastic. This lifts the metering rods when the secondary’s open. They wear out or break causing a lean wide open. All NEW air valve cams are used in these rebuilds. New float installed. The main well fuel plugs are MT13 sealed. Other sealers will not hold up to today’s fuels and will leak. The accelerator pump cups are fluorelastomer and are blue in color. They are the only pump cups that will withstand today’s fuel additives. The black pump cups are no good and will swell or shrink. All NEW choke pulloffs. The secondary throttle plates are DAG213 sealed for a good quadrajet idle quality. The top and body are chemically color bond 420 dichromated. The aluminum base is restored with a two part cleaning process that brings the aluminum back to the original finish. No silver paint or wire buffing is used. The bottom of base is then machined flat to prevent any potential warpage. The screws and linkage are yellow zinc plated. No rusty parts here. Carbs are tested on their machine that uses a pressure gauge and fuel meter. This assures no leaks and a good pump stream for the accelerator. A mounting gasket and an air cleaner gasket are included. You will not be disappointed. 7042206 Dated:5th day 1972 Included is an original choke stove and carb spacer. Fedex Ground Shipping with INSURANCE is included. The pictures do not do it justice. $400 shipped Conus |
02-25-2013, 09:50 PM | #2 |
Re: 1972 402 Restored quadrajet 7042206
02-26-2013, 01:51 PM | #3 |
Project Junkie! Fishing Poor!!
Nice carb John. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
02-26-2013, 02:39 PM | #4 |
02-26-2013, 02:44 PM | #5 |
One of the First
John, are the needles and jets set for a stock motor or has it been set up for a certain set-up on the motor it was going onto?
Thanks for the info. I'm was just curious.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 02-26-2013 at 09:35 PM. |
02-26-2013, 03:59 PM | #6 |
David, it is set at factory specs for a 72 402.
John Posted via Mobile Device |
02-26-2013, 04:02 PM | #7 |
Mike, I also have a 7042210 regular 350 carb I was going to use on my project, but could use the 7042910 California carb I have listed in another thread and sell the 210 carb.
The 210 carb is dated the 15th day of 72. Posted via Mobile Device |
02-26-2013, 06:30 PM | #8 |
John, Sending PM on the 2210 & 2910.
02-26-2013, 09:19 PM | #9 |
John, interested in the 402 carb. If other guy backs out I'll take it. Mike.
02-26-2013, 11:05 PM | #10 |
John, Put me in line if anyone changes there mind. I will take it.
02-27-2013, 01:26 AM | #11 |
Mike, I believe David is interested in another carb. David, please confirm.
You can get it on Saturday! Posted via Mobile Device |
03-06-2013, 08:45 AM | #12 |
next in line ......
1971 K5 CST Blazer 1951 -3100 5 window short bed 4sp 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
03-06-2013, 10:20 AM | #13 |
Sold to Bronze 72 Super.
Thanks for the interest. Posted via Mobile Device |
03-06-2013, 02:59 PM | #14 |
John,
Are you still selling the 7042210 ?
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
03-06-2013, 05:19 PM | #15 |
Sorry. It is sold too.
