Old 02-26-2013, 01:06 AM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Manual Fuel Transfer Valves
These are 2 way (2 in 1 out) manual fuel transfer valves. They look to be in good shape and levers are tight. They turn easily but snug. The first one (pictures in first post) has 3/8" hose barb fittings on all 3 connections and the label plate(First one is SOLD). The second one (pictures in second post) has compression fitting connections and no label plate. There are 2 mounting bolt holes on each as you can see in the pictures. Your choice, $25 shipped.
Per board rules post in thread before any PM's.
PayPal or Money Order works for me....
LockDoc
Valve #1
Leon
Old 02-26-2013, 01:07 AM   #2
LockDoc
LockDoc's Avatar
Re: Manual Fuel Transfer Valves
Valve #2
Leon
Old 02-26-2013, 02:09 AM   #3
athleo
athleo's Avatar
I'll take the first one with the plate.....pm me your paypal info.......thanks.....dwt.
athleo is offline   Reply With Quote
Old 02-26-2013, 10:51 AM   #4
LockDoc
LockDoc's Avatar
PM sent with payment info. Thanks.
LockDoc
Leon
Old 02-27-2013, 12:22 AM   #5
athleo
athleo's Avatar
Paypal sent......thanks.......dwt.
Old 03-03-2013, 01:46 PM   #6
LockDoc
LockDoc's Avatar
I still have the 2nd valve for sale.
LockDoc
Leon
Old 03-03-2013, 05:07 PM   #7
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Leon - I'm interested in the remaining valve but do you know which fitting represents the output? Trying to ensure the settings will jive with the "left" and "main" positions on the floor mounted bezel plate for the 72 aux tank option. Thanks, Pete
Old 03-03-2013, 10:04 PM   #8
LockDoc
LockDoc's Avatar
Pete,
See the picture below.
LockDoc
Leon
Old 03-03-2013, 10:36 PM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Leon - on the floor bezel the left and main tank positions are at 90 degrees to each other. Looks like this valve has them 180 degrees apart so will pass. Appreciate the help. Pete
Old 03-04-2013, 11:17 AM   #10
LockDoc
LockDoc's Avatar
Pete,
The positions on this valve are 90º between the two tank positions. One tank is the position you see in the picture. For the other position the pointer (short end of the lever) is pointed toward the outlet fitting.
LockDoc
Leon
Old 03-04-2013, 01:15 PM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
PM sent Leon...if that's case I'll take it. Thanks for clarifying - Pete
