02-26-2013, 11:25 AM | #1 |
Amount of Paint
Just trying to get a rough estimate on how much paint is needed to paint an AD truck including jams and engine bay using base coat clear coat paint
Posted via Mobile Device |
02-26-2013, 02:07 PM | #2 |
Re: Amount of Paint
Depends on the truck size, color, painter, spray gun type
02-26-2013, 08:44 PM | #3 |
Re: Amount of Paint
roughly 2.5 gal paint and 3.5 gal clear
like va4 says, a lot depends on...
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
02-26-2013, 09:08 PM | #4 |
Re: Amount of Paint
I second Ogre. I used about 2.5 gallons of paint and almost 3 of clear.. Of course I did it a quart at a time and kept going back to get more over the course of a year. I just had a local body shop fix a dent my neighbor put into my truck. The painter asked which part of my truck should he try to match it to.. Smart ass. Get it all at once so it matches.
02-26-2013, 09:57 PM | #5 |
Re: Amount of Paint
I also 2nd Orge, you might even just want to get 3 gals of color so you'll have some left over in case you need to do touch ups at a later time. Most of the base coats mix 1-1 so you'll end up with 6 gals of paint to spray...
And don't forget the primer, you may need at least 2 gals there.. maybe a high build primer will help you. |
02-27-2013, 08:56 PM | #6 |
Re: Amount of Paint
and 10 gal of filler.
you'll sand off 9 1/2 gal of it
02-27-2013, 09:03 PM | #7 |
Re: Amount of Paint
it also depends on what spraying set up you have. You'll definitely need the 2.5 gallons of paint if you use conventional gravity fed or siphon guns. If you use a good HVLP gun or spray it through an HVLP turbine, you transfer up t 80% of the material to your surface. Conventional guns that spray at 30-50 psi only transfer 50% of the material, the rest is airborne.
You also have to take your primer into consideration. If you have your primer tinted to a color close to your base color, then you'll use less base coat. The clear coat, it's always better to have more than less because that's a pretty time sensitive process. YOu want to hit your flash times bang on so buy a little extra. I would say 3 gallons of clear and hardener should do it.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
02-27-2013, 11:42 PM | #8 |
Addicted to Rust
Re: Amount of Paint
Depends on the opacity of the base. Buy at least 3-4 gallons and then mix all the gallons together to insure that the color is uniform. More paint stored correctly is never a problem, being a quart shy always is. Pearls, candies or extreme metallics will change how much you need. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
