Old 02-26-2013, 11:49 AM   #1
Dirtygrunt
S10 Frame options
Ive searched around and wondering what year and type of s10 frame to look for for a 49 chevy build. I would like to lower it and run an ls engine. I have a 96 standard cab short bed truck that i could get but from what i found it needs to be a long bed to work. Thanks for any info
Dirtygrunt is offline   Reply With Quote
Old 02-26-2013, 08:22 PM   #2
sirwilliam
Re: S10 Frame options
long box will be closer to the half ton trucks wheel base. but I have seen them on short box frames, just cut down the bed. they look short and fat, but bad ass at the same time. Up to 94 they used round steering column if you are gonna use all you can from the truck. As far as frames go they are very close to the same over the years.
sirwilliam is offline   Reply With Quote
Old 02-27-2013, 05:15 PM   #3
98layinframe
98layinframe's Avatar
If your good at welding, any s10 frame can modified easily to work. A short bed frame can be cut under the cab and lengthened, an extended cab frame can be cut down and shortened under the cab. The long bed is nicest one to run if you can find one since the wheel base is only off by an inch when you center the wheels.
As
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 02-27-2013, 10:18 PM   #4
Dirtygrunt
So I measured the s10 today and it looks like 108 wheelbase and the 49 has a wheelbase of 121. How much would be to much to safely extend a frame??
Old 02-27-2013, 10:26 PM   #5
98layinframe
Guessing your truck is a long bed then? You be better off to find an ext cab frame since they have a 122" wheelbase which is easily adjusted with a couple simple mods.
Old 02-28-2013, 02:18 PM   #6
scottty2005
so im new to this page but im building a 1947 chevy 5 window and im goingt to be putting it on a 1988 chevy s10 frame long bed standard cab but have questions about some of the bed mounts and il posted pics when i take them and figure it out as i go
scottty2005 is offline   Reply With Quote
Old 02-28-2013, 04:53 PM   #7
skymangs
skymangs's Avatar
Check my build (in sig.) I used a long bed reg cab frame. I was pretty detailed with measurements and such. Should give you a good starting point
skymangs is offline   Reply With Quote
Old 02-28-2013, 07:35 PM   #8
BlueJeep
BlueJeep's Avatar
You'd probably be better off finding a different s10. How much you can safely extend it depends on what your welding skills are and how you approach it.
Here's a long bed 49 on a 1995 extended cab s10 frame, build thread is in my signature. Front of the bed was trimmed 2.375" to fit the s10 wheelbase.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
