Old 02-26-2013, 11:58 AM   #1
dznucks
dznucks's Avatar
Longer Axle U-Bolts
Can someone help with some info on new u-bolts for a 1/2 tom '69 C-10? I have 2" drop blocks so they need to be longer than stock.
Does anyone have a part number or source for these? What about dimensions? I see Summit has alot to choose from. I know they are 5/8" in diameter, but what width do i need for a 3" axle tube? Overall length?
Thanks for the help.
dznucks is offline   Reply With Quote
Old 02-26-2013, 12:39 PM   #2
69gmcc10
69gmcc10's Avatar
Re: Longer Axle U-Bolts
Here are the dimensions of the U bolts I had made at one of the local shops for $32. The bolt should be 3/4" diamante (that is what the bolt I took out read with my calipers and they fit in the holes perfect), the U should be 3 1/2" across because it goes across the 3" axle at an angle and if you get them at least 10" they will be long enough you can just trim a little off.
3/4 x 3 1/2 x 10"
hope this helps
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 02-26-2013, 01:31 PM   #3
dznucks
dznucks's Avatar
Perfect. That is exaclty the info i was looking for. I just need to find a source for them in my area now. Does anyone know where i can find them? i dont have a spring shop near me to have them made.
Old 02-26-2013, 06:47 PM   #4
eldogg
eldogg's Avatar
I have a guy local to me Ron's Drivelines. http://www.ronsdrivelines.com/ Make sure you tell him Eric Evans from Queen City Speed sent ya.
eldogg is offline   Reply With Quote
Old 02-26-2013, 07:32 PM   #5
dznucks
dznucks's Avatar
Thanks Eric. I just learned that a driveshaft place in Marietta makes them as well. Driveshaft Services.
Old 02-27-2013, 09:03 AM   #6
ERASER5
ERASER5's Avatar
Or you could get a lift/lower block package from A-Zone for $20 or so with 4 long u-bolts and cut off the extra length after install. Any of the aftermarket groups will also have them, like Early Classic, CPP, GMC Paul's, ect.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
