02-26-2013, 02:02 PM | #1 |
oil temp gauge
Were would i install the sending unit for a oil temp gauge
Friends don't let friends drive DONKS lay it out My greatest fear is when I die my wife will sell all my truck parts for what I told her they costs |
02-26-2013, 03:20 PM | #2 |
Re: oil temp gauge
02-26-2013, 03:22 PM | #3 |
Re: oil temp gauge
On a highway truck,KW Pete etc,they are usually in the oil pan.You could probably do the same,just tap into the pan.
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
02-26-2013, 06:55 PM | #4 |
Re: oil temp gauge
Either the pan or they make a manifold that goes inline with your oil cooler or remote oil filter. It's just a block of aluminum wirh a hose fitting on either side and a threaded port for your sender. The back of the block behind the intake on a sm block chevrolet is for oil pressure not temp. Some remote oil filter mounts have a spot for a oil temp sender. Moroso and others. Some circle track oil pans come with fitting for an oil temp guage (usually a manual type guage is used) as equipment
02-26-2013, 08:29 PM | #5 |
Re: oil temp gauge
Yes its a sb 350 and realy wasnt tryin to drill the pan didnt want to remove it couse its in the truck
