Motor mount stands
I have a 70 c10 and I put in a 383 stroker. The front end is off of a 72 c10. Is there a difference in engine mount stands from a 70 to a 72?
Posted via Mobile Device |
17's too small
Re: Motor mount stands
Not from what I have researched. the inline 6 is different from the small block
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows |
the boat guy
I think big block stands are also different. Oh and they can be swapped from side to side and move the engine foreward or back also.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Thanks guys. The reason I ask is because I can't install my headers due to them hitting on the brackets. Any suggestions?
Junior Member
I had similar problems so I went with '74 mounts and stands. I am not sure if it will work for you, but worth a try.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
What headers are you running,I had my motor in the 6cyl. spot and slid it back to the v-8 holes while I upgrade to a 700r4 trans.Now my headers touch the bottom a-arm shaft I used a 74 crossmember on mine.I had a 70 C-10 that I did the same thing to and same brand of headers .Chevy parts will swap right over my a@#,u just gotta find the right combination.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
I got tube moter mount towers to clear my headers and it gives u the better styl motor mounts
I just looked at my motor mounts and they aren't quite lining up on the frame. I swapped the crossmember out of an 84 burb and I have the motor mount perches. When I set them up the original lower holes work fine but the frame side is about 1/4" off of the frame. I'm not sure if this would help with your issue. I have to figure out how my gap is fixed.
1968 Chevy SWB stepside original USAF truck http://67-72chevytrucks.com/vboard/s...d.php?t=483462 |
I think I'm going to go with the tubular style mount towers. Does anyone know who I can go thru to get some?
No limit engineering has the styl I used work great classic industries and cpp have some that look good
