02-26-2013, 02:59 PM | #1 |
1965 Chevy C10, 2005 4.8L/4l60
who does the axle redrill?
just wondering who I could take some axles to to re drill them from 6lug to 5
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-26-2013, 03:06 PM | #2 |
Re: who does the axle redrill?
Any CNC Machine shop could do it, just a matter of finding one that is willing to do "odd jobs" that are not standard CNC type work. I know my local place always does "odd things" for me with no problems.
2001 Yukon Factory Grey Metallic~2" DJM Key front drop/3" DJM Rear Springs~stock 16" chrome steel wheels~5.3/4L60E~Volante CAI w/under bumper air scoop~Magnaflow 10426 Bullet muffler~DDM LED all exterior lighting/55w-5000k HID Hi/Low/35w Fog Last edited by TexasSteve; 02-26-2013 at 03:15 PM. |
02-26-2013, 05:35 PM | #3 |
Moser Engineering does them. http://www.moserengineering.com/
02-26-2013, 07:46 PM | #4 |
Well really any machine shop, they don't need CNC for that, they just need your specs. Adapter plate could could be an option.
1965 One Ton GMC 4x4 project Have 3 trucks in my photo album, building them into one custom but original looking 4x4 dually reg cab pickup with 133" wheel base. |
02-26-2013, 10:28 PM | #5 |
I wish I could find a shop in the Houston area that could re-drill mine to 5 bolt. The shops I have called say because of the 6-bolt pattern they won't re-drill the axles....safety issues.
02-26-2013, 10:51 PM | #6 |
I would contact Strange Engineering and see what a set of super street axles would cost,ther is too much liability to re drill. I've had much better service with other companies than Moser.
02-26-2013, 11:15 PM | #7 |
02-27-2013, 02:27 AM | #8 |
I can't believe they turned you down for safety issues sounds more like they just didn't want to do it. People cut and weld axles all the time, it just needs to be done by a pro. Maybe look online for custom diff builders and get their opinion?
02-27-2013, 08:48 AM | #9 |
Junk yard!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
02-27-2013, 10:40 AM | #10 |
I had my '65 Suburban axles done through Moser. They "filled and drilled" my originals to a 5 lug pattern, back in the mid '90s and they're holding OK. No safety problems or isues here
02-27-2013, 10:54 AM | #11 |
67-72 parts collector,…
If you use a 71-72 brake drum on your re-drilled axles, the center hub diameter will also have to be turned down to match the hole in the brake drum.
The other option,... would be to also drill the 5-lug pattern in the 6-lug brake drum.
02-27-2013, 11:54 AM | #12 |
Ol' Blue Viking
Try Mike Minette at
Minette Enterprises 11586 Reeder Rd, Dallas, TX 75229 972-241-7184 (call first) Mike has not done axles for me, but he is well respected in D/FW. We have been using him for over 25 years. Let me know if he does drill your axles.
Driving Paw-paws truck into the Sunset! |
02-27-2013, 02:22 PM | #13 |
Ill give hi a call. Thanks Rogue_64
02-27-2013, 09:02 PM | #14 |
He did the axles for my old roomates 69 back in the 80's. 6-lug to car 5x4.75 pattern & turned the hub down slightly.
02-28-2013, 03:54 AM | #15 |
Im about to do the same and I've contacted this shop.
He told me that they probably send it off to another one but job will be done in a week. http://www.clutchandpowertrain.com/ Might be a problem when u're in TX they are located in Mobile, AL
Johnny G -----------Vehicles-------------- * Chevrolet C-10 Stepside 1962 * Audi A4 Avant Quattro TDI 2008 * Sachs Compact 50cc 1967 |
10-18-2014, 10:32 PM | #16 |
Minette Enterprise, Dallas Tx. can redrill your axles. We just did a set of axles and rotors for Aron at Gas Monkey Garage. We also change lug patterns on aluminum wheels and hubcentrically bore wheel centers.
10-18-2014, 11:00 PM | #17 |
Welcome to the board!
GOD BLESS AMERICA! |
10-19-2014, 12:30 PM | #18 | |
I am curious... what about cutting a wheel center loose to alter back spacing? Southwest Wheel used to do this once upon a time but said no the last time I referred someone there.
10-19-2014, 05:48 PM | #19 |
Thinking of doing the same thing sometime. Gonna get wheels first!!!
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
