Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 02-26-2013, 05:23 PM   #1
fastbagged68
fastbagged68's Avatar
Difference between 2wheel drive frame and 3/4 ton
Does anyone know if there is a difference between 1/2 ton 2 wheel drive vs 3/4 ton 2 wheel or 4 wheel drive frames....
fastbagged68 is offline   Reply With Quote
Old 02-27-2013, 01:49 AM   #2
Captainfab
60-66 Nut
Re: Difference between 2wheel drive frame and 3/4 ton
The C10 frames are slightly different than a C20 frame, but they are interchangeable. The K series frames on the other hand are a good bit different than the C series frames. I don't know if you could use a K series frame as a C series replacement.
