Old 02-26-2013, 08:03 PM   #1
steve'62
steve'62's Avatar
What is this and could it be draining my battery?
I have a battery problem. Is this a regulator, could it be fried? It's right by the horn. It's constantly warm which is a bad sign. If I was to replace it what would it be? Part number ect.
steve'62 is offline   Reply With Quote
Old 02-26-2013, 08:07 PM   #2
thunder71
thunder71's Avatar
Re: What is this and could it be draining my battery?
Looks like the horn relay
_____________________________________
66 C10 shortbed stepside KEEPER
66 C10 longbed stepside SOLD
69 C10 shortbed stepside SOLD
71 C10 custom deluxe long fleetside SOLD
thunder71 is offline   Reply With Quote
Old 02-26-2013, 08:15 PM   #3
SCOTI
SCOTI's Avatar
If it's electrical, it can drain the battery. Put a volt meter on the batt & disconnect it from the circuit watching for a voltage change.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-26-2013, 10:16 PM   #4
steve'62
steve'62's Avatar
You guys are awesome , it's the horn relay. PO tied a bunch of stud into this. I don't have the horn hooked up. There is an alarm hooked into it, can I bypass the relay?
Old 02-27-2013, 09:01 AM   #5
tincan1966
tincan1966's Avatar
If the relay is constantly warm, then it either defective internally and staying in the "closed" or sctivated position, or with all the extra wiring, it is grounded.
I would get a new one(realitivly inexpensive) and connect it correctly.
Another thing to check, is under the steering column there will be a connector for the turn signals, etc. In that connector is a black wire that goes up to the horn button. Sounds to me like that circuit could be grounded. Disconnect that connector and see if relay cools down clicks if you plug it back in. If you plug the horn in, does it go off without pressing the button?
tincan1966 is offline   Reply With Quote
Old 02-27-2013, 10:09 AM   #6
steve'62
steve'62's Avatar
Good info, thanks, I will do some trouble shooting when I get home. I think the relay is shot but also need to check if its grounding out. I wish I had a booklet for the alarm that the PO connected to see why it's run through the horn relay and if it has to be run through that relay. I don't want to ditch the alarm but I may have to if that is part of the issue.
Old 02-27-2013, 10:20 AM   #7
tincan1966
tincan1966's Avatar
For some clarity- when I mentioned the relay might be grounding out, I meant activated. The relay has basically 3 wires- a red-12v battery+, a green-goes to horn, and a black, which goes to the horn button in steering column, which when the button is pushed, grounds the wire thru the steering shaft, and activates the relay(closes the connection internally) and sends power to the horn.
If I was to guess, I would say the PO used the relay as a power source for the larm(judging by the added small guage wire I saw in the picture connected to the battery+ wire)
If you can get to the control box of the alarm and let me know what type it is I MAY be able to help with a wiring diagram.
Old 02-27-2013, 11:01 AM   #8
steve'62
steve'62's Avatar
I will see what I can find out about the alarm this evening. I'm following that the circuit may be closed due to a short in the column area, plug, ect. Thanks, ill post updates later
Old 03-01-2013, 11:26 AM   #9
steve'62
steve'62's Avatar
Looks like everything is working right now. There must have been a short in the column or the horn button somewhere. I unhooked the plug for the horn at the relay and the relay cooled down. It seems the battery has stopped being drained! Thanks guys for the help......
Old 03-20-2013, 12:00 PM   #10
Gmforce
Gmforce's Avatar
The alarm is connected to the horn because the alarm activates the horn when it gores off....
Gmforce is offline   Reply With Quote
