Old 02-26-2013, 09:04 PM   #1
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
How low can you go with stock control arms on the front?
We recently got a 72 C10 Highlander long box truck. We're going to cut it down to a short bed, and stuff a heavy 6 cylinder in it. I haven't messed with dropping these trucks, so I'm wondering how low you can go with stock engine cross member, and stock front control arms? I tried searching, but it didn't come up with any real useful info. The plan for the rear suspension is up in the air. This is going to be a budhet build for my little bro, so throw any ideas out there guys. Thanks Ryan.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-26-2013, 09:39 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: How low can you go with stock control arms on the front?
I'm at 4" with stock spindles and factory bumpstops.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-26-2013, 09:49 PM   #3
BigCountryx
BigCountryx's Avatar
5.5" on my blazer with 255/40/20's with zero problems.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
Old 02-26-2013, 09:52 PM   #4
Mike C
Mike C's Avatar
Will have some bearing on how you lower it. You should still be able to get the camber in spec with 4" spring, and 2 1/2" spindle on top of that would get you 6.5". But I would consider doing the spindle with a 2" spring which would get you 4.5" with NO alignment issues and plenty of room for tire.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-26-2013, 09:57 PM   #5
leddzepp
Moderator
leddzepp's Avatar
I have 5.5" in the front with factory arms and x- member. I would not go any lower with a static drop. I can't slide a floor jack under my x-member. I have no alignment issues at all.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-26-2013, 10:21 PM   #6
Mikes_70
Hey guys , it's funny I was looking at my build with a 2 inch drop spindle and 2 inch springs and my wheels scrape the lower when turned all the way to one side or the other . It sits on 17s . Is it safe enough to trim up the lower to clear or do I have to go to a larger wheel .
Thanks for the space .
Mikes_70 is offline   Reply With Quote
Old 02-26-2013, 10:51 PM   #7
Dieselwrencher
How do you guys think the 4" drop springs will take an 1100lb engine?
Ryan
Old 02-26-2013, 10:54 PM   #8
Mikes_70
What are you putting in it ???? A duramax ??? Probably not good
Old 02-26-2013, 11:09 PM   #9
brad_man_72
the boat guy
24v cummins according to his sig...
You may want to get 2" big block springs and trim to taste. I hear these trucks are pretty easy to bag.
Old 02-26-2013, 11:39 PM   #10
Dieselwrencher
Good idea Brad. Bags would be the ideal choice. It'll be either a 12v or a 24v. Not sure which yet.
Ryan
Old 02-27-2013, 01:48 AM   #11
oldschool18
oldschool18's Avatar
you can bag the front end of a chevy truck pretty easy, if your going with that big of a motor you want to put the biggest bag you can get up front......
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 02-27-2013, 11:17 AM   #12
biohazardbill
Truck in garage is bagged on factory control arms, 2.5" drop spindles and the suicidedoors bag setup (cup and plate) Could go another 1/2" or so if you cut the cups down a bit.
biohazardbill is offline   Reply With Quote
