02-26-2013, 09:19 PM | #1 |
Steering column
So my tail lights, brake lights and turn signals in the rear work intermittently at best. I have chased down all grounds, checked fuses to no avail. I believe the problem exists in my steering column with the turn signal switch. My column has an extraordinary amount of play when shifting from park to drive etc. So I was going to replace the rag joint and column. Enter my budget! I promised the wife this would be a slow build and have reached the end of the allowed budget for now! Does this column here look to be decent? Is this going to turn into a you get what you pay for issue? Looking for any input here as I am brand new to this whole project.
I have a '66 short box with a th350 auto(column) and a 305 V8 http://www.ebay.com/itm/1-Day-Blow-O...c8e973&vxp=mtr Thanks for any help Jason Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
02-26-2013, 09:36 PM | #2 |
Re: Steering column
I have nearly the identical column. The only difference is mine is bare not chrome. ('60 1 C30 Panel) Its an excellent column. I love that is a tilt.
It is a basic column. Its not fancy. Definitely not on the level of an Ididit, but absolutely on par with a factory column. |
02-26-2013, 09:56 PM | #3 |
Re: Steering column
Woog, the turn signal switch is new from when I did a painless kit. I have been wanting a tilt column for a while as I am 6'4" and think it could make the drive a little more comfortable.
Space, thanks for the review, I think I will jump on it. Posted via Mobile Device |
02-27-2013, 01:32 AM | #4 |
Re: Steering column
Are you saying that the steering wheel and shaft move side to side and up and down??? Sounds like the upper and lower bearings are trashed if so--
As far as the electronics--you need to probably start isolating specific circuits to take resistance and continuity checks-- Posted via Mobile Device
My '65 Suburban Resto build-- http://smg.photobucket.com/albums/v6...65%20Suburban/ And it's story of being 'saved' http://www.jalopyjournal.com/forum/s...d.php?t=631495 |
02-27-2013, 12:15 PM | #5 |
Re: Steering column
66jax avoid the headaches and buy that steering column cause its a good deal...I bought mine on ebay similar to yours (hot rod GM universal 32")$199.00 shipped and very happy with it. I also bought the rag joint, OD universal joint and collapsable steering shaft as a kit from CPP. If you need sum help on the install (slight fab work) just pm me....check it out..
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
02-27-2013, 01:30 PM | #6 |
Re: Steering column
66jax----bought a non column shift (floor shift 32") tilt raw metal from the same seller. definitely not the quality of ididit or flaming river (have had both). my only b$$ch is you can move the steering a little (up & down) in the different tilt positions and my stock steering wheel doesn't fit perfect--gap between wheel and column more than normal. don't know if i can make the horn work yet as my truck is stripped. good deal for the price though. I also slid the column down as far as it would go for more leg room.
1961 chevy K10 my build is------------61K10 build |
02-27-2013, 08:57 PM | #7 |
Re: Steering column
Ok. This is very informative. I have 66 c10. Is that a 32" column? Is it possible to replace the wiring inside the column easily?
02-28-2013, 12:48 AM | #8 | |
Re: Steering column
Never mind, found one on ebay. Thx Posted via Mobile Device
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 Last edited by Trsmotrhed; 02-28-2013 at 12:56 AM. Reason: found what I was looking for. |
02-28-2013, 12:12 PM | #9 |
Re: Steering column
Just keep in mind you might have to buy a steering wheel for a 9 bolt mount to go with the adapter supplied with this column... I wanted to go with a Mooneyes steering wheel with the standard GM 3 hole mount and adapter but their was a big gap between the column and adapter which was an eye soar....
02-28-2013, 02:00 PM | #10 |
Re: Steering column
you can see the gap in post #7 not bad but could be better. mine came with the adaptor as a bonus. all the 9bolt wheels are custom looking as my truck will be stock or close to it.
02-28-2013, 02:44 PM | #11 | |
Re: Steering column
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
