02-26-2013, 11:15 PM | #1 |
86 sierra won't start
i just bought a 1986 gmc sierra and brought it home parked it in the driveway and now its not starting with out jumping the battery once you jump it it drives fine but as soon as you shut it off its dead and it wont start i test drove the truck and even at the persons house i got it from we must have moved it around at least 4 times it worked fine but now its not starting i went out and bought two brand new batteries that are recommended for my truck for about three days it worked no problem started up on the first shot and now its dead again and wont start unless you jump the batteries how does this keep happening?? i just noticed is my dash lights don't work and my reverse bulbs and brake light bulbs keep being burnt out and i changed them when i got the truck 4 days ago
02-26-2013, 11:50 PM | #2 |
78K & 79C Jimmys
Re: 86 sierra won't start
hi welcome
can you check the battery for voltage,before,while starting,then running if the alt is over charging it may blow things so 12, before low of 9,when starting high 14.5,charging and pics everybody like pics
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
02-27-2013, 12:38 AM | #3 |
I would do like motornut said and check the alternator real good. If that checks out then I might start thinking maybe there is a draw on the system somewhere. Might have a short somewhere.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
03-02-2013, 10:19 AM | #4 |
ok great i will try checking the voltage and see what that is i just got the truck back from the shop there saying it was the belt that's connected to the alternator they said it was worn out so they replaced it its been running good but after i start it the battery lights always on until i give it some gas then it goes away
03-02-2013, 10:33 AM | #5 |
sounds like an laternator not working or bad wiring
03-02-2013, 11:39 AM | #6 |
Ensure the connections are all clean and tight. Verify the battery voltage as well as charging system voltage when it's running. If you don't have a meter you should pick one up even if it's a cheap one.
