meowMEOWmeowMEOW
Coil overs on trailing arm rear.
Anyone have a picture of their setup running coil-overs on the rear? I need to replace my smushy rear springs and nitro shocks with something like a Qa1, but would like to see how you are running them, and which length you ran.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: May 2012
Re: Coil overs on trailing arm rear.
Will be welding mine out tonite,will get you a couple of pics tomorrow when i finsh.
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 |
Here's a few pics of mine.
![]() ![]() ![]() ![]() ![]() I wanted the truck low,and bare frame it is sitting 13" from the floor to the frame.!!! I can still go 7" up in one inch moves if need be.
meowMEOWmeowMEOW
THAT is what I'm looking for my man.
Could you show me a better pic of the axle brackets? It looks like you have a pretty big drop built into the bracket to accommodate the CO length. Are those the qa1 (which length?) Thanks dude....im so jealous that you have the weather to work on it....I'm just staring at mine all winter.
I order the brackets from S & W race cars, for the longer length.Hate to rub it in ,but it's 68 here today in LA.(Lower Alabama) and no those are cheap comp engineering coil overs 12". Figured I would up grade after everything is built an settled, to strange or QA1. Get you a better pic of the brackets this evening.Went with the longer brackets to get the truck as low as I could,the brackets that come with the coil overs from comp. are three inch's shorter ,which would raise the frame three inch's higher.
Here's a link to the build thread few more pics there.http://67-72chevytrucks.com/vboard/s...d.php?t=551185
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 Last edited by contagious102; 03-01-2013 at 05:25 PM. |
nice work . might want to guset the frame where you welded the crossmember for the shocks thats what i did.
meowMEOWmeowMEOW
Thanks for the pics contagious. I'm thinking about just making a set of brackets, but those sw units aren't too expensive and the adjustability looks nice if you need to change the setup.
