![]() Join Date: Sep 2006
Anyone using early corvette or camaro finned valve covers
Wondering what to do with the pcv valve hole if you have to run one or just put a breather in place of it
Re: Anyone using early corvette or camaro finned valve covers
I have these, but you must mean the earlier ones. Ive seen guys put a hole in them for a pcv, or put a bung in an oil fill tube and get a 64 corvette threaded pcv valve. For that matter I guess you could tap threads in the vc
I believe I have the ones you have
Use the pcv! Positive crankcase ventilation is a good thing. Removes combustion gasses and re-burns them through Your carb. Also makes your carb work correctly. Also use the correct pcv valve. Some flow at different rates changing the "vacuum" Flow to your carb. If you don't use it, oil will get everywhere. I also run a pipe or hose from the other side to the air filter housing closing the entire system off. And yes I have those exact valve covers.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Old member
I just finished redoing mine. I have the PCV valve on drivers side along with a corvette oil filler tube that has a vented cap on it. The passenger side has a K&N filter in the hole. I had oil blowing out of the dip stick. The pvc valve was clogged up and I had a solid cap on the oil fill.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Aug 2008
#8 | |
Old member
![]() Quote:
the boat guy
Running vette valvecovers on my boat with a breather tube only. I've been meaning to make some kind of hidden under the intake pcv system. Or put a pcv valve between the carb and distributor in the back of the intake. Oil gets everywhere!
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
what are those exhaust things? where headers normally are. And how is that engine mounted. Im trying to picture the boat and its not making sense. not a boat person
boats use water cooled exhaust manifolds// that motor is pretty spiffy
#12 | |
Old member
![]() Quote:
#13 |
the boat guy
The front of the engine/rear of boat has a cast plate made by edelbrock that mounts just outside the timing cover w 4 bolts.
The rear of the engine has a bell housing with mounting tabs on each side at the bottom. And as stated water cooled exhaust manifolds. Posted via Mobile Device
#14 | |
Old member
![]() Quote:
