Old 02-27-2013, 07:25 AM   #1
JCD
JCD's Avatar
Non stock exhaust manifolds
I have a set of these on the 67 SS camaro.
I've never seen these types of manifolds on any 67-72 truck so far.
I know they will bolt up to the engine.
But has anyone used these on their truck?
And what problems if any did you run into..
J.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
Old 02-27-2013, 07:33 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Non stock exhaust manifolds
Guaranteed that they will hit the engine mount stands. You can't use any manifolds that hang low like that with stock 67-72 engine mounting. That's the reason these trucks used the ramshorn type of manifolds, because they are situated significantly higher.
Old 02-27-2013, 07:36 AM   #3
JCD
JCD's Avatar
Figured it was so.. Thanks
J.
1971 Demon 340
1969 SS El Camino
Old 02-27-2013, 08:18 AM   #4
midniteblues
midniteblues's Avatar
heres some pics too show you this is how my truck came
check out how they modded the frame mounts
the manifolds are not excactly like the ones you pic'd they are really close
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 02-27-2013, 08:29 AM   #5
JCD
JCD's Avatar
Thanks.. I know these manifolds are more efficient than the rams, but by how much I'm not sure. I wonder if anyone makes a mount that allows a bolt in swap.
J.
1971 Demon 340
1969 SS El Camino
Old 02-27-2013, 08:48 AM   #6
midniteblues
you could have these if you wanted them just pay shipping
oh an i wanted too say that these were set in the 6 cly holes with a 283 v8 so I dont think the bottom hole would line up in the v8 postion(that may need to be drilled i never checked)
these might even be modded 6 cly mounts
they did a good job braceing an welding them up but are not very pretty also
these were in a 67 with the wider frame rail
Old 03-01-2013, 07:03 PM   #7
JCD
JCD's Avatar
Thank you for the offer.. it's a generous one.
But I'm not at the point that I can afford to take my daily driver apart for this modification, let alone afford the manifolds..
So I'll reluctantly have to pass.
If you're willing to offer the mounts to anyone else on the forum..
Please do so.
Thanks.
J.
1971 Demon 340
1969 SS El Camino
Old 03-03-2013, 10:38 AM   #8
midniteblues
Please do so.
Thanks.
J.
just thought i would offer these too you instead of them being in the scrap pileI really didnt think anybody would want these and i surely dont need them
if anybody would/could use these shoot me a pm
