axle??
ok (c10 5 lug)( k10 6 lug) after that is there any other differnts.Thanks
Re: axle??
c10 is 2wd k10 is a 4x4.
![]() Join Date: Jun 2010
Re: axle??
What is the reason for your question. That might be able to clear things up a little. Are you looking to switch rear ends or something?
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
Re: axle??
ok yes I am looking at a swap.I have 1968 2 wheel drive that is making alot of noise.
POL make kit to put the 1973-87 rear end into the 1968.My 68 has 6 lugs and I was look for a better gearing 3.73 is way to many RPMs.And There is only two gears for the 6 lug that wouls be a bolt in.3.73 or 3.08.The 3.42 with the tire size that I have would work for the overdrive trans that I am going to put in.Thanks |
Re: axle??
Assuming the overdrive you are going to is in the .70 to .73 range, and assuming a "normal" sized tire (P235/75R-15 or so) I would recommend the 3.73 axle ratio.
I would guess the 3.42 is not enough axle with the overdrive (unless you are using a teeny tire). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#6 | |
Re: axle??
K
Re: axle??
Knowbody that I would trust around here.Rear has a lot of play in it and it growls.After I posted this I found a Calculator Looks like the 3.73s would be better.
