02-27-2013, 07:09 PM | #1 |
59 Apache power Brakes vacuum on 235
I am thinking of installing power brakes to my 59 Apache and was wondering if the vacuum take off from the carb inlet manifold (used to go to the wipers I presume now blocked off) will be sufficient. I have the original 235 engine still and see no other vacuum port to connect to. Any advice would be appreciated. Thanks in advance.
02-27-2013, 07:11 PM | #2 |
Re: 59 Apache power Brakes vacuum on 235
I installed a CPP power disc kit on my 55 with a 235 and worked great!
02-27-2013, 07:21 PM | #3 |
Great news but to where did you connect the vacuum?
02-27-2013, 07:30 PM | #4 |
Welcome to the forum Krimics. I bought a new fitting for the carb and used that vacuum source for the brakes. Right now I don't have wipers as no vacuum attached. RainX works wonders and my vacuum wipers have issues anyways. Probably eventually go to power wipers. That or just put a T in the vacuum line for the wipers.
Posted via Mobile Device |
02-27-2013, 08:18 PM | #5 |
02-27-2013, 09:20 PM | #6 |
The square nut (pipe plug) on the side of the manifold is where you install your vac. port.
Remove the plug and replace with fitting and connect your P/B hose line. Put a upside down U in the line at the firewall that extends at least as high as the top of the carb. This will help separate gas vapor from collecting in the P/B booster. |
02-28-2013, 12:38 AM | #7 |
Many thanks to you all for replying and pointing out the process I will follow.... Will take pictures when I eventually get to install then post.
Thanks again for taking the time. |
