Old 02-27-2013, 08:00 PM   #1
rollin thunder
rollin thunder's Avatar
washing engine bay???
Hey, I really want to clean the engine bay before installing new engine, whats the best way? I don`t have hot water to the pressure washer i was planning to pressure wash and use some kind of degreaser. cold and miserable but i think it should work.
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373
1984 Chevy C10 short bed
2001 Chevy Impala police cruiser
2001 Chevy Silverado 1500 Z71 4wd extended cab dd
rollin thunder is offline   Reply With Quote
Old 02-27-2013, 08:03 PM   #2
Jonboy
Slots go on anything!
Re: washing engine bay???
I have had good luck with purple power and a pressure washer. Let it soak, rewet it, and get after it.
Old 02-27-2013, 08:13 PM   #3
Sabaka454
Sabaka454's Avatar
You need a pressure washer if you want it really clean. See if you can borrow or rent one.
Sabaka454 is offline   Reply With Quote
Old 02-27-2013, 08:29 PM   #4
Damon23
Damon23's Avatar
Soak it with a heavy degreaser, let it sit, then come back and spray it off. Then go back with the degreaser and get out a brush and go to town and hit it with the degreaser again. It is not easy work but will pay off in the end. I had the motor out of my 79Z28 and did this but let it dry and masked off some things and took the time to hit all the places I wanted to hit with the satin black and the sides of the fenders with body color and so on. If you can take a day and do this you'll be happy in the end and it will be easy to maintain. This is only if you are going after a nice clean detailed bay. If you just want it clean, then you can skip all of the masking and such.
Experience is something you gain when you didn't get what you wanted in the first place.
No great defeat was ever just possible in the beginning.
Damon23 is offline   Reply With Quote
Old 02-27-2013, 08:32 PM   #5
rs74
rs74's Avatar
I usually get a couple of cans of Gunk brand or equivalent engine degreaser. I spray one can on and let it dwell for a good while sometimes a couple of hours. Then right before I wash it down I will spray the next can or what is left of the first on it and then power wash it. I never have hot water to the power washer and it works just fine. Of course I have 4000 psi washer and it does a great job. A smaller psi unit will do just fine just take your time and do a good job. Sometimes I will take a rag and wipe down the firewall real good to give that extra clean.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-27-2013, 10:01 PM   #6
rollin thunder
Awesome! thanks for the reply guys, So degreaser let it soak and pressure it, sounds like a plan and damon 23 thanks for the input on the spraying. i have not decided if i am going to paint it or not I was going to base it off of what it looks like clean the paint seems fine just dirty as all get out
Old 02-27-2013, 11:18 PM   #7
Squareforceone
Squareforceone's Avatar
i vote paint lol doesn't take that much time and is easy to do with the motor out, and it's cheap and makes it look so much nicer
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 02-27-2013, 11:31 PM   #8
Damon23
Damon23's Avatar
You'll be surprised how bad it will look when it is clean. You could just get lucky and just use a general cleaner with a rag and wipe it down after you pressure wash it and be fine. My pressure washer is 2700 psi and worked just fine. Just seize the moment while the motor is out and you can get to everything.
Old 02-28-2013, 01:37 AM   #9
PAWS 72
PAWS 72's Avatar
Don't use easy off what ever you do on the firewall or inner fenders. Unless your going to paint it
Just dont even ask.
PAWS 72 is offline   Reply With Quote
Old 02-28-2013, 01:41 AM   #10
rs74
rs74's Avatar
Just dont even ask.
Sorry, probably was the last thing you was expecting after using it.
Roy
1987 R10 shortie
Old 02-28-2013, 03:04 AM   #11
andrewmp6
You can use oven cleaner but you gotta get it all off before painting.
andrewmp6 is offline   Reply With Quote
Old 02-28-2013, 11:55 AM   #12
Low87
been here longer than Liz
Low87's Avatar
Soak in degreaser. Foaming tire cleaner works pretty well for cleaning up rubber stuff.
Use aluminum foil to mask off anything you don't want wet. Foil also works great as masking if you paint the bay. Conforms to odd shapes nicely.
As stated, pressure washer is best. I've gotten by with a good nozzle on a garden hose before, but also used wire brushes.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 03-01-2013, 05:31 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
normally i use degreaser but I tried oven cleaner
didn't work as i thought it should on heavy grease
was washing undercoating gease off inner fenders
at a wash bay,with kinda hot water,i'll stick to degreasers
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-01-2013, 05:36 PM   #14
Low87
Low87's Avatar
WD-40 does pretty good on tough spots too. Doesn't harm paint either.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 03-01-2013, 06:20 PM   #15
86swb
Born a Chevy Man
86swb's Avatar
That WD-40 is great for so many things.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 03-01-2013, 07:10 PM   #16
rollin thunder
Got it done! will post pics later, my camera took a dump and will not get a chance to take any till monday. I ended up using this cleaner called awesome from the dollar store and the pressure washer it work great! just cold and miserable and paint isnt bad just 2 spots need to be taken care of the cross-member and down below where the battery tray goes. But will repaint it all as you pointed out might as well and Thanks for all the input guys!!
Old 03-02-2013, 11:23 AM   #17
eldogg
eldogg's Avatar
Kerosene or Purple Power in a cheap pump up sprayer.
eldogg is offline   Reply With Quote
Old 03-02-2013, 03:18 PM   #18
rusty76
rusty76's Avatar
I find that oven cleaner isn't as good as it used to be. So if you get lucky and some old lady is throwing out a can or two that is old, more than five years or better grab it. I had some that I bought years ago and sprayed it on and ran out. I got a new can of it and it do anything compared to the old stuff. Same brand just different make up I guess. Preasure washer is a great thing. Waitin on some pics now.....
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
