Anybody know what this is for ?
I am going through my original wiring harness on my 71 chevy c10 350 3 speed manual trans has no ac, ps, pb I ran across this wire that is dark brown in color that comes out of the bulkhead and was in the firewall gutter and not used. It is key on fed and the wire is only 12 inches long and will not reach the engine at all. I have looked at the wiring diagram and in the bulkhead there is only 1 brown wire that is for the voltage regulator and this is about 5 feet short. Any ideas I really would just like to know what it is used for. Here is a pic of the wire and the plastic connector. Thank You
Fuzzy |
RAT1968 '68 Cab/'71 Parts
Re: Anybody know what this is for ?
Don't take this one to the bank, but I think that's the juice for a tranny kick-down. I had an extra brown with that connector
on my original harness. And the fresh M & H harness has one, too. I just let it "dangle" in a safe place and called it good.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
![]() Join Date: Dec 2011
I actually think that's for the TCS harness, it plugs into it
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350 1971 K-10 Custom Deluxe 1971 K-10 Custom |
Cool. I have absolutely *no idea* what a TCS is.
Transmission controlled spark. The harness itself plugs into the trans, a temp sensor on the pass. side of the engine, a idle solenoid on the carb and two relays on the firewall above the emergency brake on the outside in 71 and the inside in 72. Most guys throw um away
My first thought was it goes to the brake porportion valve being so short?
Brake proportioning valve wire is tan and that is hooked up and works
Fuzzy |
Yeah. It's for the trans.
Not a kick-down plug. But a plug for the trans none-the-less. ![]() I don't use it with my TH350. I'd make a safe bet that the manual trans doesn't use it either. But what do I know? One thing's for sure: On *my* truck, you can let it "run wild".
Mine is dangling free also. The last 42 yrs
Ed F 1972 Sierra Grande White Top Medium Olive 402 bb / Camper Stock, Loaded, Straight & Aged Nicely, No Tilt Original Resto would be nice $ ![]() |
How does REF ACC FEED sound to everyone? What wiring diagrams did you use the generics or the 71 service manual's?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
My '71 has the same wire as well, I posed a topic on the forum quite some time ago and I think we all came to the conclusion it was for the TCS. Like said above, it's usually thrown away as it is just emission crap that makes the truck run poorly when it is not warmed up, if I recall.
71 K20 64 GMC mud truck |
![]() Join Date: May 2011
Tim, what is the REF ACC FEED?
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
#13 | |
Actually I had not noticed it before nor seen if referenced. From the description it is an underhood igniton voltage reference power connector for testing that can also be used for an underhood accessory feed.
#14 |
Thanks Tim! I personally find the wiring on these trucks to be interesting to say the least! My stock wiring harness has radio wires piggy backed off trans wires that are plugged into the radio fuse spade, who would have know they had anything in common.
